Home -> Forums -> Construction -> Bricks -> Used 30 bags cement for 3 units ( 1 unit tipper) msand. What would be approx mixing ratio?
Fri Jan 20, 2017Total posts : 2
Topic: Used 30 bags cement for 3 units ( 1 unit tipper) msand. What would be approx mixing ratio?
My contractor used 30 bags of cement for 3 units (one unit tipper) of m-sand for brick work. So, what would be the mixing ratio? Is it 1:6?
Fri Jan 20, 2017Post  #1
Dear Vinu,
       The ratio is cement ; sand. Now cement bag is having 1.25 cft content than 1;6 ratio means  bag and 7.5 cft of sand. Now measure tipper and calculate the ratio.
Fri Jan 20, 2017Post  #2
See the link which are very help full in construction.
3792
1767
1460
2475
i want to see the front &back view of this wall unit with its cabinet uses
Last answer on 7/3/2020 10:26:24 PM. Forum started by jyoti agrawal
2549
Water for Construction
2328
Sand units
1706
Sand units
1526
Sand units
4366
WHAT IS THE RATIO
2834
Am looking out for some latest designs of TV units and portrait display tables
Last answer on 7/9/2021 7:38:00 PM. Forum started by RVkamat
2395
hi, i am sunny....i need some help in designing a lcd unit with some light effec
Last answer on 12/10/2011 6:45:54 PM. Forum started by sunny
2346
what material use in wall unit
Last answer on 5/31/2012 4:15:46 PM. Forum started by sonali
2876
Last answer on 5/31/2012 4:16:57 PM. by Gunjan Utraja. Forum started by sonali
2945
Can I get 300cm long tv unit
Last answer on 8/16/2018 12:51:10 AM. by S L Gupta (Civil Engg). Forum started by sadekhussin
24854
greeting cards display unit
Last answer on 2/18/2021 10:26:55 PM. Forum started by archi verma
2550
Factory Main Door
1741
1548
Insulating roof using used cement bags
Last answer on 3/26/2015 1:35:41 AM. by JAI PRAKASH. Forum started by Arvind Bhaskar
Last answer on 7/9/2020 4:06:40 AM. by S L Gupta (Civil Engg). Forum started by sarasrl
7513
Brick Advice Urgent
2880
Bricks
2794
brick calculation
2566
Cost of Brickwork
4895
2821
2350
3172
bricks
5659
2014
3238
5135
Use of Solid Concrete Bricks
1341
1846
1480
1797
2967
fly ash bricks
2230
1723
Concrete Mix Ratio
Air
Air Conditioner AC: Tips before buying Air Conditioners
Check out GharExpert buying guide for Air Conditioners AC so that you could know about different types of Air conditio..
Glass
Glass Shower Enclosure
Today people are using shower enclosure in their bathroom to make it look elegant. To create a feeling of openness and..
Ready
Ready Mix Concrete
Hard
Skylight
