Home -> Forums -> Construction -> Foundation -> Using MSamd slurry for filling house foundation.
Sat Oct 24, 2015Total posts : 2
Vinod
Vinod
Topic: Using MSamd slurry for filling house foundation.
Is MSand slurry (wet & rubber type powder) good for filling house rubble foundation ie. from ground level to floor level? Now a days its commonly used in Kerala due to scarcity of other filling materials, but I'm a bit doubtful about its usability since it acts as rubber in wet condition and returns to same condition in the presence of water even after dried.
Sun Oct 25, 2015Post  #1
You can use it.
Mon Oct 26, 2015Post  #2
Dear Vinod
       When you your self say that is like to rubber in wet condition than avoid this..
2957
Need suggestions
1393
2587
mortar thickness in brick joints in foundation
Last answer on 8/23/2011 8:47:15 PM. by S L Gupta (Civil Engg). Forum started by ahsan
1064
2603
Using old bricks for construction
Last answer on 11/3/2011 11:02:20 PM. by susandixon. Forum started by Col MP Singh
3879
2321
1681
rain water filled in foundation
Last answer on 8/8/2013 11:32:06 AM. by S L Gupta (Civil Engg). Forum started by jks
1844
House plan
Last answer on 12/29/2015 12:51:33 AM. by JAI PRAKASH. Forum started by Rohit Sharma
2063
concrete filling
Last answer on 4/18/2014 7:54:24 PM. by shaik khaja nayab rasool. Forum started by shaik khaja nayab rasool
1827
foundation
Last answer on 10/5/2014 1:20:44 PM. by SANJAY DUSANE. Forum started by nitu
2679
2749
2926
Skylights
Last answer on 12/31/2020 2:07:37 AM. by Rajan. Forum started by hemapradeep
2111
can arch be used in house does it indicate negative energy
Last answer on 12/31/2020 2:26:19 AM. by Karan. Forum started by preethi
2061
treatment for white ants
Last answer on 9/20/2014 12:17:36 PM. by S L Gupta (Civil Engg). Forum started by richlyn
1890
1749
Suggestion on foundation building
Last answer on 7/2/2020 10:05:39 PM. by S L Gupta (Civil Engg). Forum started by Sandeep
2684
Pillar
2140
Curing urgent
2372
structure work
5166
Pillar foundation
2203
new house
2821
building a house
1991
Construction Agreement
3089
Foundation
2272
Foundation
1476
10048
3660
Foundation
2115
Structure proof checking
2558
Foundation design
2459
2467
Saria and cement
3656
Wall Thickness
2678
3179
13267
Steel Type
Earth Filling
Designing
Designing a Foundation
Hard
Skylight
