Home -> Forums -> Construction -> Brick work -> Using additional horizontal RCC band below window level and earthquake resistance
Tue Aug 23, 2016Total posts : 1
Topic: Using additional horizontal RCC band below window level and earthquake resistance
Whether using one additional RCC belt just below window level ie. in between foundation rcc belt and lintel belt, leaving gap only at door spaces improve earthquake resistance of the building?
1) Rubble foundation
2) RCC belt
3) Brick wall up to window base level
4) RCC belt ( This is what I'm referring as additional reinforcement)
5) Brick wall
6) RCC Lintel
7) Brick wall
8) RCC flat roof.
IS there any real benefit of using such an additional RCC band in the event of eathquake?
Wed Aug 24, 2016Post  #1
Dear Vinu
        Only three rcc band one at plinth level. door level and roof level is required.
2288
2144
2737
1498
9540
Earthquake Design - Plinth Band and Lintel Band
Last answer on 12/31/2020 2:02:44 AM. by Love thy community. Forum started by Kitan
3915
2406
surveying
Last answer on 5/27/2021 1:53:39 PM. by Bill Shiphr. Forum started by shaik khaja nayab rasool
1673
1470
1914
Dutch Hood Canopy Awnings
Last answer on 1/24/2022 12:11:10 AM. Forum started by Shel Jones
1593
Respected Sir,We are constructing a individual house at an area of approx 450sq
Last answer on 12/2/2016 11:53:14 AM. by S L Gupta (Civil Engg). Forum started by ranjeet
1518
Last answer on 12/2/2016 11:43:21 AM. by S L Gupta (Civil Engg). Forum started by ranjeet
2834
Choosing the right type foundation and structure for house
Last answer on 9/30/2011 11:52:30 PM. by S L Gupta (Civil Engg). Forum started by Vinod
3924
Cantilever porch
Last answer on 11/17/2021 10:04:24 AM. by S L Gupta (Civil Engg). Forum started by Capt. Devendra Kumar
1741
Suggestion on foundation building
Last answer on 7/2/2020 10:05:39 PM. by S L Gupta (Civil Engg). Forum started by Sandeep
1097
Are TMT's building really earthquake resistant
Last answer on 8/20/2018 12:14:24 AM. by S L Gupta (Civil Engg). Forum started by Anu Mohan
1352
How to design my house to be more flood and earthquake safe.
Last answer on 9/27/2018 1:25:04 AM. by S L Gupta (Civil Engg). Forum started by Betty Varghese
3657
wals
3252
compound wall
21767
3270
Bedroom Wardrobes information
1485
1941
1724
2214
2514
1487
1902
Brick or ACC block
2015
1643
2144
4588
Brick wall on RCC slab
3919
2604
Earthquake
Hard
Skylight
Types of Cement
