Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Water proofing during construction and painting
Thu Oct 24, 2013Total posts : 2
vamsi
vamsi
Topic: Water proofing during construction and painting
My house is now in brick work stage. I want to know what can be done up front for proper water proofing of walls. For slab, we bought some liquid and mixed it with the concrete. Hence I am assuming the slab is more or less water proof.
Are any similar stuff available in the market that can be used for walls? If yes please provide me the details such as Brand, Cost, how to mix it with plastering material. I am assuming that if this is properly done, I can go for some decent exterior paint, without Putty and that will be enough to protect the walls from rain.
Also what are the uses of Putty for interior walls,and what can be the price per sft for good quality putty+paint including labor.
Thanks,
Vamsi.
Fri Oct 25, 2013Post  #1
Dampness causes most of the damage to the contents of the building. It often leads to the growth of molds and bacteria and creates an unhealthy environment for those who occupy it. Dampness gradually impairs the affected part of the building so this problem should be attended as soon as possible.
Precautions you can take during a new construction:
Fri Dec 03, 2021Post  #2
Adriano Peres
Adriano Peres
I'm shopping around for a paint sprayer to not only paint my screen, but alot of rooms in my house. I have an air compressor and just need the sprayer.
Problem is I can't find one that says it's ok to use with Latex paints. Almost all of the sprayers I have come across seem to be for automotive and industrial applications.
Can you recommend one for me for under $100? There is a Home Depot, Harbor Freight and Lowes here. Or I can just purchase online.
3170
APP membrane
2240
2771
2237
3836
ROOF WATER PROOFING / TANKING
950
Sir, I have constructed 12000 lit concrete sump. Plastering done with cement,san
Last answer on 7/3/2020 9:23:58 PM. Forum started by sunder
1708
Need help about painting and wall water proofing
Last answer on 3/11/2014 3:08:54 PM. by Ahmed. Forum started by vamsi
2574
What solution can be taken for paint that comes out during monsoon from walls...
Last answer on 12/1/2009 3:08:11 PM. by H S Rathi. Forum started by madhuri
2240
2509
2347
lift pit water proofing
2902
Terrace water proofing
2161
1842
1800
1972
2846
Last answer on 6/17/2013 5:17:52 PM. by Navneet Jharia. Forum started by g.s.rajan
3972
water proofing of water tank
5062
5817
3799
9892
2674
4631
4147
2870
5218
5020
3664
4068
1868
2803
2613
2470
2641
1811
3614
6260
Earthquake
Importance
Damp
Damp Proofing
Protect
Preventive
Water for Construction
General
