Water proofing method
Wed Mar 11, 2015Total posts : 3
ringwang
ringwang
Topic: Water proofing method
Dear sir,
I am thank for your valuable respond for all my problem. here  i have water leakage problem for few old existing R.C.C building. here we done my zicosil and also trape creat chemical treatment but that does not work well. Now i thought to laid 2" screed concrete with untra techi. water proof chemical. as per my knowledge that better than those water proof chemical coating. please can you give me one suggestion.
Thu Mar 12, 2015Post  #1
apply a coating of liquid silicon. It will go into all cracks and changes to solid state. That is the best for avoiding leakage issues.
Thu Mar 12, 2015Post  #2
ringwang
ringwang
Post subject: coating only work for fresh time
Jai prakash sir,
 applying coating only work during fresh time or only first monsoon time. once its dry by sun heat again same problem occured.
Fri Mar 13, 2015Post  #3
Have you used Liquid silicon before?
2323
2237
2240
2408
950
Sir, I have constructed 12000 lit concrete sump. Plastering done with cement,san
Last answer on 7/3/2020 9:23:58 PM. Forum started by sunder
3170
APP membrane
2348
lift pit water proofing
3836
ROOF WATER PROOFING / TANKING
2902
Terrace water proofing
2342
Waterproofing leaks from terrace
Last answer on 5/15/2015 11:08:13 AM. by prit123. Forum started by island
1996
1619
FENGSHUI METHOD ....I HAVE NO IDEA..ISIT THAT IT IS ALSO LIKE OUR VASTHU BASED O
Last answer on 4/8/2011 7:23:18 AM. by sabina vanjani. Forum started by D.Ramachandran
3972
water proofing of water tank
1961
2835
3165
Basement waterproofing
2338
Related to Sunken Slab
2072
Last answer on 4/6/2016 11:43:24 AM. by S L Gupta (Civil Engg). Forum started by zakia sultana
AuStRalia!!CaNaDa" 91- 8769373431VASHIKARAN sPeCiAlIsT
Last answer on 12/30/2024 1:08:23 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:08:17 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:08:11 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:08:05 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:58 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:52 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:46 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:40 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:34 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:27 AM. Forum started by rupeshji
Muslim-Shakti-Astro 91-8769373431Black Magic Specialist In Dubai,,qatar
Last answer on 12/30/2024 1:06:59 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:47 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:39 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:33 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:27 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:21 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:15 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:09 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:03 AM. Forum started by rupeshji
Boy / Girl 91-8769373431~iNtErCaSt LoVe MaRrIaGe;;LoVe BaCk SpEcIaLiSt
Last answer on 12/30/2024 1:05:50 AM. Forum started by rupeshji
Damp
Damp Proofing
Protect
Preventive
Fire
Basement Design Ideas
Guideline for laying DPC
Earthquake
Electric
Electric Shock Proof Home
