Thu Nov 05, 2015Total posts : 7
Techman
Techman
Topic: Whats the max. room size for rcc flat roof without beams?
What is maximum room size that support rcc roof without beam in between and load bearing walls. I've also seen that in some places of rcc roof steel bars are provided in box form instead of mesh...will it act as small beam without projections? If yes, up to what room size we can use it instead of actual beam?
Fri Nov 06, 2015Post  #1
Any extension more than 100 Sq.ft. needs and extra beam in the lantel. So the room size more than 10x10 needs an extra beam in the centre.
Sat Nov 07, 2015Post  #2
Techman
Techman
Sir, I see a lot of houses with bedroom/living room sizes 12ftx13ft,13ftx14ft etc. without any visible beams. In my present house plan the bedroom size is 12ftx13ft but engineer is suggesting more steel rods through the centre within same 4" thickness ie. Not visible beam. Is it right?
Sat Nov 07, 2015Post  #3
Yes you are correct. That beam is not visible as that has to be inside the lintel.
Mon Nov 09, 2015Post  #4
Dear Tack man
         You should use 12''x 5'' beam in middle with 6 to 8 bars of 16mm with rings of 8mm dia @ 6'' c/c.
Wed May 17, 2017Post  #5
Ganesh Jadhav
Ganesh Jadhav
Actually sir ,
If i want my living room 18ft*14ft
Is this possible with invisible beam if yes then give size and specifications of beam
Thu May 18, 2017Post  #6
Dear Jadav,
          You can lay consolidate beam on 14' side, the size of beam is 18''x7''. 7'' thickness of beam portion 5'' will be in RCC roof and remaining 2'' up side will be covered in concrete below flooring. use 8 nos MS Steel bars of 20 mm dia 4nos on top and 4 nos on bottom with 8mm dia ring 4'' center to center.
Mon Jul 23, 2018Post  #7
            Thank you.
Roof Beam
24767
9894
2054
4431
2606
3575
1769
Roof fabrication advIse
Last answer on 10/21/2015 11:43:50 AM. by S L Gupta (Civil Engg). Forum started by richlyn
4665
Regarding Beam
2850
1st floor partition wall through the center of 14ft x 13 ft room rcc roof
Last answer on 11/1/2015 6:50:49 PM. by JAI PRAKASH. Forum started by vinu
2260
advise
Last answer on 8/16/2013 1:07:43 PM. by S L Gupta (Civil Engg). Forum started by faroque
5862
12252
2191
Size of the Roof Level Beam in RCC framed structure
Last answer on 1/30/2015 12:12:31 PM. by S L Gupta (Civil Engg). Forum started by Arvind Bhaskar
3293
2720
8421
Roof Beam crack
3623
18
Decorate
Decorate your Veranda
Veranda or Gallery is an additional space for relaxation and entertainment. It is an opened gallery which is usually o..
Right size cupola
