Home -> Forums -> Construction -> Foundation -> Whether 6 x 8mm TMT bars are enough for rcc belt over rubble foundation for 2 story house?
Thu Sep 22, 2016Total posts : 0
Topic: Whether 6 x 8mm TMT bars are enough for rcc belt over rubble foundation for 2 story house?
My contractor suggested 6 numbers of  8mm TMT bars and 6mm TMT for tie boxes for rcc belt of width 1 feet and thickness 6 inch over the rubble foundation for load bearing walls. So, is it enough or should I go for 10mm/12mm TMT bars?
3753
1702
2301
1509
1683
24765
1622
1589
1502
2613
4070
steel requirement
2840
Choosing the right type foundation and structure for house
Last answer on 9/30/2011 11:52:30 PM. by S L Gupta (Civil Engg). Forum started by Vinod
1529
1064
2898
RCC Roof
3039
use of tmt bar
3179
Last answer on 3/14/2021 11:13:22 AM. by S L Gupta (Civil Engg). Forum started by venkatesan.pt.
2684
Pillar
2140
Curing urgent
2372
structure work
5166
Pillar foundation
2202
new house
2821
building a house
1991
Construction Agreement
3089
Foundation
2272
Foundation
1476
10047
3660
Foundation
2115
Structure proof checking
2558
Foundation design
2459
2467
Saria and cement
3656
Wall Thickness
2678
3179
13267
Steel Type
TMT
Type
Designing
Designing a Foundation
HSD
