Sat Jan 28, 2017 | Post #1 | Navneet Jharia
Join date: Dec 2010 | Post subject: PVC conduits be placed under or above TMT bars i...
Hello..! Vinu,The PVC conduits should be placed above TMT bars ...Regards.
Sat Jan 28, 2017 | Post #2 | Navneet Jharia
Join date: Dec 2010 | Post subject: Laying of PVC conduits in roof slab
Mon Jan 30, 2017 | Post #3 | vinod singh
Join date: Jan 2017 | PVC electrical conduits to be put in between top and bottom reinforcement mesh (avoiding conduits in both bottom and top cover )in slabs Ensure the effective depth of slab is maintained as specified in structural design. | |
Mon Jan 30, 2017 | Post #4 | S L Gupta (Civil Engg)
Join date: Mar 2008 | Dear Vinu, See and read below article
Cement concrete is strong in compressive strength but weak in tensile
strength. To increase tensile strength we use mild steel bars in cement
concrete. Steel bars used in cement concrete provide good strength to
the structure. A strong building structure is what all need for their
homes, offices and steel is the best option used with cement concrete.
1) Overlapping in Steel Bars in Reinforced Cement Concrete
There should be no joints in steel bars used for RCC work. If it is
necessary to use small length steel bars, proper overlap should be
given.
The joints of bars should be welded in case the diameter of
bars is more than 36 mm. Overlapping of bars should not touch each other
and they should be kept apart. Where it is not possible, overlapping
bars should be bound together at intervals not exceeding twice the
diameter of such bars with two strands of steel wires trusted tight. The
overlap should be staggered for different bars. The length of overlap
should not be less than 50 times the diameter of steel bar.
2) Precautions while Bending, Binding and Placing Steel Bars in RCC Work
- Steel bars are clear, free from loose mil scales, dust, loose rust and any oily materials.
- The bars used at site are manufactured from reputed brand and have a full length.
- Use full length steel bars in beams, slabs etc if not possible,
proper overlap should be given in steel bar and overlap should be
staggered.
- Tor, ribbed and twisted steel bars are used as they have more
tensile stress. Also they are economical and have more strength in
cement concrete.
- The bars must be in full length according to the design.
- Proper sizes/ height of crank bars are given in slab and beams etc.
- Proper support under crank bars of beams and slabs must be given.
- Steel bars are not disturbed while lying cement concrete.
- If steel bars are more in number in beams, the bars are placed in two layers by giving spacer between the layers.
3) Checklist/Points before Laying Cement Concrete
- Form work /shuttering should be checked for line, level and its strength.
- Steel bars and their placing should be checked.
- Proper cover to steel bars and adequate numbers of sports/chairs under crank bars must be checked.
- Proper planks or plates provided for walking over reinforcement are not disturbed during working.
- Raw materials should be proper and sufficient in quantity.
- Electrical pipes, fan box etc. should be laid before lying cement concrete.
- Gap in shuttering plates is sealed properly by jute bags /mortar /rubber etc.
- Shuttering plates are properly oiled.
- Curing arrangement must be checked in advance for smooth curing after laying RCC slab.
- Precautionary arrangements are taken in case of rains etc.
Questions (39) | |
1908 views | 1 answers | Last answer on 11/19/2020 4:21:26 AM. by S L Gupta (Civil Engg). Forum started by Sanzana Hosen | 3087 views | 1 answers | Last answer on 1/20/2017 1:58:48 PM. by S L Gupta (Civil Engg). Forum started by vinu | 2913 views | 0 answers | Last answer on 1/5/2022 12:27:42 AM. Forum started by Vineet Sethiya |
| 4070 views | 4 answers | Last answer on 7/4/2020 2:20:25 AM. by JAI PRAKASH. Forum started by Raghavendra | 9893 views | 3 answers | Last answer on 9/19/2020 12:43:29 AM. by shaik khaja nayab rasool. Forum started by rishi | 3039 views | 5 answers | Last answer on 6/12/2018 1:37:59 AM. by S L Gupta (Civil Engg). Forum started by sonu.211 | 191901 views | 97 answers | Last answer on 1/23/2022 3:32:01 AM. by TanyaHerrera. Forum started by Bimlendra Jha | 5689 views | 3 answers | Last answer on 6/30/2013 5:14:56 PM. by Navneet Jharia. Forum started by Purvi Panchal | 2613 views | 3 answers | Last answer on 7/23/2018 11:36:52 PM. by S L Gupta (Civil Engg). Forum started by AMIT KUMAR VERMA | 3225 views | 2 answers | Last answer on 1/27/2017 3:25:08 PM. by Rahul. Forum started by Rahul | 1622 views | 2 answers | Last answer on 1/25/2022 12:11:46 AM. by S L Gupta (Civil Engg). Forum started by Muhammad | 1589 views | 1 answers | Last answer on 7/4/2020 4:22:40 AM. by Er.S.K.Jain. Forum started by Vineeth V | 1503 views | 1 answers | Last answer on 7/4/2020 2:17:25 AM. by S L Gupta (Civil Engg). Forum started by Betty Varghese | 24767 views | 5 answers | Last answer on 7/4/2020 12:22:02 AM. by JAI PRAKASH. Forum started by Techman | 13756 views | 4 answers | Last answer on 1/26/2017 11:24:59 AM. by Madhankumar. Forum started by upendra | 3980 views | 1 answers | Last answer on 2/25/2013 11:42:01 AM. by S L Gupta (Civil Engg). Forum started by paresh | 2957 views | 1 answers | Last answer on 12/28/2012 11:27:53 AM. by S L Gupta (Civil Engg). Forum started by prabhjeet | 2898 views | 2 answers | Last answer on 7/4/2020 12:19:59 AM. by JAI PRAKASH. Forum started by ARVIND GOYAL | 2275 views | 2 answers | Last answer on 5/7/2014 6:58:38 AM. by ajaywahi. Forum started by ajaywahi | 11 views | 0 answers | Last answer on 12/21/2024 12:29:49 AM. Forum started by rupeshji | 9 views | 0 answers | Last answer on 12/21/2024 12:29:40 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:29:32 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:29:24 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:29:18 AM. Forum started by rupeshji | 10 views | 0 answers | Last answer on 12/21/2024 12:29:12 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:29:05 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:58 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:28:51 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:44 AM. Forum started by rupeshji | 3 views | 0 answers | Last answer on 12/21/2024 12:28:38 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:31 AM. Forum started by rupeshji | 8 views | 0 answers | Last answer on 12/21/2024 12:28:24 AM. Forum started by rupeshji | 15 views | 0 answers | Last answer on 12/21/2024 12:28:18 AM. Forum started by rupeshji | 17 views | 0 answers | Last answer on 12/21/2024 12:28:10 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:03 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:27:56 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:27:22 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:27:16 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:27:08 AM. Forum started by rupeshji |
