Home -> Forums -> Construction -> Bricks -> Wire-cut Clay bricks vs Concrete bricks, which one is good for strength and durability?
Sun Aug 14, 2016Total posts : 1
Topic: Wire-cut Clay bricks vs Concrete bricks, which one is good for strength and durability?
Wire-cut Clay bricks vs Concrete bricks, which one is good for strength and durability of load bearing wall construction? I'm also doubtful about whether the concrete brick makers use the raw materials in standard ratio, but in case of wire-cut clay bricks such quality issues are not there...
Wed Aug 17, 2016Post  #1
Dear Vinu,
In strength concrete brick is strong and durable if properly made. For quality test crushing strength.
2951
2015
3919
2944
1331
2864
FLYASH OR CLAY BRICK
3445
6434
2339
3109
concrete brick or clay brick
2852
Bricks
3978
2144
5411
How can we identify the First class brick. How it helps for the building strengt
Last answer on 4/10/2010 3:43:09 PM. by S L Gupta (Civil Engg). Forum started by gk
7500
Brick Advice Urgent
3054
3419
2405
1854
Last answer on 1/5/2022 9:14:05 PM. by sanjay agarwal. Forum started by saradha
7500
Brick Advice Urgent
2855
Bricks
2786
brick calculation
2555
Cost of Brickwork
4881
2810
2339
3163
bricks
5637
2003
3212
5125
Use of Solid Concrete Bricks
1614
1331
1834
1470
2956
fly ash bricks
2197
1714
Various Types of Bricks
Concrete Mix Ratio
Tips for Cement Paint
Brick Arches
Specification of Brick
Brick Pillar
