Home -> Forums -> Construction -> Layout and House Plans -> how about Hidden beam in 35' X 15 ' Living area ?
Sat Apr 16, 2011Total posts : 5
tiwari_p_k
tiwari_p_k
Topic: how about Hidden beam in 35' X 15 ' Living area ?
     Hi
I have Living room + dining area of 35' X 15'. This area also contains area for stair case on right side. The slab thickness in this area is 5" with Steel bars of size 12mm placed @ 4"c/c.
Considering this area of living and dining, it has 3 vertical beams of and one long connecting horizontal beam in it as shown in attached image. How good it would be to replace those beams with Hidden Beams? I am thinking of applying hidden beams to utilize the full height of living room (9'5"). Also if there are so many normal beams inside living rooms it would look odd and then I need to apply False ceiling to hide those normal beams.
So considering my plan details is it good idea to apply hidden beams in place of normal beams? If not then what is least height of beam that I can use for my normal beams. Currently my architecture says the beams height will be 15", out of which 5" will be merged inside slab and remaining 10" will be hanging in living area.
Attaching my beams plans. Inside this plan beam numbers 12,13,14,15 23,24,25 and 26 I would like to make hidden beam.
Please advise on it.
Many thanks.
regards,
Pras
Attachments: COLUMN AND BEAM PLAN.JPG on Sat Apr 16, 2011,
ground floor plan.JPG on Sat Apr 16, 2011,&n
Sat Apr 16, 2011Post  #1
Dear Tiwari
          you have not given the dimensions in your plan. In the absence of dimension it is not possible to give any suggestion about the beams.
Sat Apr 16, 2011Post  #2
tiwari_p_k
tiwari_p_k
Gupta Ji,
Thanks for your immediate reply. The dimensions of Living and dining area is shown in attached image "ground floor plan.jpg" in my above post. The total dimension of Living and dining area excluding kitchen is 34.5' X 15'. Kindly have a look at both attached architecture diagrams. May be you will get better idea of dimensions.
Thanks again in advance for your reply.
Pras
Wed Apr 20, 2011Post  #3
Dear Tiwari
      After seeing plan of your house, the beam shown from column C13 to C14 is not required but the other beams are necssary and height may be reduce from 15'' to 12'' with increase in the steel bars up to 25%.
Wed Apr 20, 2011Post  #4
tiwari_p_k
tiwari_p_k
Thank you so much for reply :)
Tue Jun 21, 2011Post  #5
Chakkara
Chakkara
Post subject: Consealed Beams
You can avoid the beams by increasing the slab thick to 6" and the reiforcement of 12# @ 4" C/C is too high for that area even its 6" Slab Thick.
Your Plan shows lot of useless columns and beams Even the Circular Column inside the Living. It looks so hard even you give Rich treatments.
You can also avoid the B25-B26 by giving a Cantilever beam from Beam 31 and that beam too can hide with the Last Step of the Staircase. The Folded Steps will give a nice look ( See the attached file).
The consealed beams also required only if you have any main walls in the First floor area and  let I know the First floor slabs are Sloped one.
Please Check with some Experienced Structural Engineer.
All the best and Regards
Chakkara
Attachments: Int-1.JPG Tue Jun 21, 2011,&n
2234
HIDDEN WINDOW DECOR IN LIVING AREA
Last answer on 7/23/2018 11:37:55 PM. by S L Gupta (Civil Engg). Forum started by Nimit Panwar
1743
Sir my plot size 15"35 please sir susesad me
Last answer on 8/8/2017 12:02:44 PM. by Saurav anand. Forum started by buntysuman
1802
Want to construct a new house in limited budget, area 35*35 .
Last answer on 10/20/2015 2:24:22 AM. by JAI PRAKASH. Forum started by Kiran
2072
Last answer on 1/8/2018 11:06:10 PM. by S L Gupta (Civil Engg). Forum started by ravikumar
2501
i want a vastu plan for north facing plot N-45,S-35,E-25,W-25 is this a good plo
Last answer on 2/3/2014 10:57:56 PM. by acharya :- keshava. Forum started by dev
1715
Please send me a house plan area of 10.5*35 in ground floor my front is south
Last answer on 3/17/2017 2:05:20 PM. by S L Gupta (Civil Engg). Forum started by Manoj jha
2501
1688
area 35 fit south,38 fit north and 56 fit east , 54 fit west with 15 fit deft in
Last answer on 9/26/2014 10:57:02 AM. by seema tyagi. Forum started by binod kumar singh
1979
10048
2824
6881
1700
SIR, I WANT TO CONSTRUCT MY HOUSE 3RD FLOOR. TODAY THER IS G 2FLOOR.I WANT EXTEN
Last answer on 3/5/2016 9:50:33 PM. by JAI PRAKASH. Forum started by cvsatav
855
Kindly refer my attachment,For G 2 residential building, M15 grade used ,for roo
Last answer on 7/4/2020 2:29:32 AM. by S L Gupta (Civil Engg). Forum started by Sathya
928
Last answer on 7/2/2020 9:41:30 PM. by S L Gupta (Civil Engg). Forum started by Sathya
3900
For G 2 residential building, column size 9"*15",16mm 4rod,12mm 2rod used.. hori
Last answer on 7/4/2020 2:29:23 AM. by S L Gupta (Civil Engg). Forum started by Sathya
2629
Roofing elevation
Last answer on 12/24/2014 4:28:01 PM. by S L Gupta (Civil Engg). Forum started by Sai Pavana
1366
2691
2924
2188
2184
2793
4520
1890
2284
2266
2767
3464
2356
1967
2242
3595
2324
2091
2792
1548
2114
Rugs
Rugs for Living Room
Living Room Furnishing
Living room furnishings add life to your dull living room. In this article, you will find some interesting and practic..
Centering
Living Room Ceiling
Photo-`Furnish`
Photo-'Furnish'
So you have decided to change the interiors of your home. You need to have a very careful eye on big range of furnitur..
Living Room Sofas
Sofas create the sense of aesthetics coupled with comfort and luxury. Picking the right kind of sofa for living room p..
Living Room Color Schemes
Paint Colors impart a beautiful effect in your every room if chosen perfectly. But sometimes the excessive use of bold..
Modern
Modern Living Room
Modern living room consists of pastel colors, soft furnishing, and sofas with padded arms that always compliment your ..
