Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> beam sizes
beam sizes
Wed Nov 19, 2014Total posts : 5
rupesh
rupesh
Topic: beam sizes
We have given contract for construction of our house and with regard to the same the ground floor slab is over. While calculating the actual sizes we have taken the beam sizes as 12" inches Height and 9" inches width which are visible. Where as the contractor is taking the sizes as 18" inches height and 9" inches width and he is calculating measurements in cubic feet. The difference of 6" inches in height is being calculated which is gone into slab. Our question is when he has charged for the slab as per sq ft, how can he charge the 6" inches of beam both in slab cost & beam cost. Kindly clarify our doubt.
Rupesh Kanjani
9885294133
Thu Nov 20, 2014Post  #1
Dear Rupesh
          You have not given the agreement items but as I under stand from your query that you have have problem in roof slab payment and beam payment. If contract is through rate i.e. labor and material than he claim slab payment in sft and wanted extra payment  of beam portion in slab. In my view he can claim extra steel of beam in slab but not for concrete and labor etc. If his agreement is on labor base than he can claim steel bending binding labor.
Fri Nov 21, 2014Post  #2
rupesh
rupesh
Post subject: beam sizes
Thanks for your reply, as our agreement with the contractor is for total construction and the rate for the Beam is Rs.200.00 per cubic feet and rate for the slab is Rs.200.00 per sq ft.Our dispute with him is that he has charged the slab cost as per sq feet which is ok but he is charging for the 6 inches beam which has gone into the slab,for example the visible beam size is 0.75 x12 inches where as he charging for 0.75x18inches.So please clarify whether we should pay him as per his quote or pay only for the steel used.
kanjani rupesh
Sat Nov 22, 2014Post  #3
ringwang
ringwang
Dear Rupesh,
you should follow Mr. Gupta advice. here in my site they are doing labor contract they claim but i did not consider that 6"in beam. we calculate only beam visible area. If material contract you should pay extra payment for the 6" beam steel cost.
Sat Nov 29, 2014Post  #4
rupesh
rupesh
Post subject: invisible beam cost
Sir Gupta ji
How to arrive at the cost of steel to be paid for invisible slab beam.please reply
Sat Nov 29, 2014Post  #5
Dear Rupesh
       It is not possible at this stage to calculate the actual used steel. Tentatively if your beam is 9'' wide, 5'' in slab and let suppose  20' length than contents are= 20x .75x.42=6.3 cft x 3kg per cft=18.9 kg. More over you can take idea from black smith i.e. bar binder who will tell you about bars placed in beam. In general at top 2nos bars are laid to secure rings of beam which cant be more than 18.9 kg.
859
Kindly refer my attachment,For G 2 residential building, M15 grade used ,for roo
Last answer on 7/4/2020 2:29:32 AM. by S L Gupta (Civil Engg). Forum started by Sathya
933
Last answer on 7/2/2020 9:41:30 PM. by S L Gupta (Civil Engg). Forum started by Sathya
4055
1982
3308
4036
labor rate for RCC work
3844
Roof Beam
1706
SIR, I WANT TO CONSTRUCT MY HOUSE 3RD FLOOR. TODAY THER IS G 2FLOOR.I WANT EXTEN
Last answer on 3/5/2016 9:50:33 PM. by JAI PRAKASH. Forum started by cvsatav
1770
3651
5225
2694
Steel Size
Last answer on 8/21/2014 12:31:17 PM. by S L Gupta (Civil Engg). Forum started by ferous
6894
1625
Residential Structural needs
Last answer on 10/5/2016 12:15:38 PM. by S L Gupta (Civil Engg). Forum started by Padmanabhan
1539
Guide me
2789
4454
2826
1802
RCC foundation instead of brick foundation
Last answer on 9/23/2015 8:37:51 AM. by gpeter. Forum started by gpeter
5825
3803
9897
2676
4631
4147
2874
5225
5047
3667
4074
1869
2803
2616
2391
2476
2642
1812
3621
6265
Centering
Right size cupola
Dining
Dining Room Ceiling
