Home -> Forums -> Construction -> Basement -> what is best basement solution for houses with low ground level to street level?
Wed Mar 01, 2017Total posts : 1
pramod
pramod
Topic: what is best basement solution for houses with low ground level to street level?
what is best basement solution(pillars and plinth)  for houses with low ground level to street level?
My plot (35X50) is 5 feet below to street level. please share thoughts and any plans to minimize extra cost to elevation ?
Wed Mar 01, 2017Post  #1
Dear Pramod,
          For detail knowledge of basement you should visit the basement section of construction on the website gharexpert.com.
For plan write to support@gharexpert.com
A reference
Designing interiors of basement is a challenging job since the basement lacks natural light and air. The interior design of basement needs highly specialized skills as there is low ceiling, ducts, beams and columns. The basement interior design requires more attention in comparison to the ordinary designs of building to the requirement of house owner.
Uses of Basement
Before starting basement design, the house owner should consider various uses of basement i.e. Home Office, Gym, Storeroom, Guest Room, Playground for Kids etc. Some house owners want to convert the space in an apartment having bedroom, living room, bathroom and kitchen etc. To have spacious feel in the basement with low level, use light color on walls and ceilings. The interior design of basement is costlier than the space to be designed above the ground.
Problems of Basement Interior Design
The basement interior design should be obtained from professional interior designer since the basement is located at the bottom of the building or either built under the ground or slightly above the ground. The following problems are noticed while doing basement interior design.
  • Ventilation
  • Duct adjustment
  • Leakage and de-watering
  • Low level hanging pipes
  • The ceiling has low height
  • Dampness, moist and wet basement
  • Provision for water supply line and sever line
Basement Interior Design Ideas
Basement Ventilation
To get natural ventilation, install windows towards road/street above ground level of the area. Exhaust fan should be fixed in the space between ground and roof of basement towards road/street.  Utilize duct pipe to exhaust air above the top of the roof if the basement is fully underground. Install faux windows with duct to counteract the effect of enclosed space. The vent should be fixed to provide natural ventilation.
Basement Lighting
A bright and clear lighting sets the mood for entire basement and make most effective use of basement space. Fix artificial lighting to compensate the absence of natural light. Task lighting/workspace lighting should be installed with separate control where necessary. The following are a few superior choices of basement superior lighting.
Install florescent lighting that is energy efficient and is preferred to incandescent lighting worldwide. It consumes one third of energy of incandescent lighting and lasts ten times longer. Fluorescent lighting reduces carbon emissions and air pollution.
You can opt for halogen lights that offer crunchy and very clear light. These lights best work as can lights, track lighting, and task lighting. Use halogen lighting in combination with other basement lighting options.
You can go for another option of LED lights which like fluorescent lighting produces less than 1/20th of the heat produced by incandescent lights. This lighting reflects focused beams of light and is best used as task lighting such as desk lamps, nightlights, and spotlights, in cabinets and in closets.
Basement Flooring
Ceramic tile floor is one of the best choices for basement flooring. It is damp-proof and remains cold under bare feet. Before installation of basement floor, make sure the floor of basement is leveled with grout or mortar. Ceramic floor tiles are practical and add to the beauty of your basement. Also you can lay carpets or mats to add comfort to the entire basement.
Waterproofing Treatment
Do waterproofing treatment during the construction of basement. To know details of waterproofing of basement click at the link given below.
Provisions for Flood Water
Make arrangements with outer wall of the basement for pumping water out in case of leakage or flood etc.
Division of Basement Area as Per Requirement
The space should be divided according to the requirement with independent locking arrangement. To make basement spacious, paint wall and ceiling in light color.
Minimum Circulation Space and Internal Walls
Make use of glass panels in basement design to add beauty and to get natural light.
You should minimize circulation space to provide approach to maximum rooms. Do not design circulation space diagonally. Also you should minimize internal walls and make them as thin as possible to save the space.
Basement Wall Colors
Several basement color options like different shades of green, orange, blue, and yellows will certainly boost up newly finished basement. Such shades of colors definitely add brilliance to previous dark and gloomy basement.
Basement Doors
Fix sliding pocket door to obtain maximum space and provide minimum doors as for as possible keeping in view the purpose of privacy.
Facilities in Recessed Portions
Construct book shelves in recess of walls to save space and install electricity points in the recessed portion of the ceiling of basement to overcome the difficulty of low level.
Provision of Toilet Facility towards Roadside
Toilet facility should be provided with walls towards road or street to make independent use of basement.
  Basement walls always needs special care because of outside pressure of soil. Read about What care should be taken for designing and constructing the basement walls.
Basement Flooring need extra care because of moist and dampness conditions. Read details about basement flooring options and precautions you need to take while choosing flooring for basement.
Finish your Basement Ceiling with great ideas from GharExpert ceiling design gallery. Make your basement more inviting with the right choice of ceiling design. Get new style and defination to your basement.
Basement interior design can fulfill your dreams of enjoying more space. You can highlight dark space of basement in effective ways. Read this article to know more 'Basement Interior Design’ and 'Basement Design Principles' .
Construction of basement and multi storey building is the need of the hour as there is less availability of land and rates of the land are very high. We get additional usable space by constructing either basement or upper floor.
Basement serves the purpose of extra space and provides strong base for upper storey.
  A dry basement is a fun place to have. Usually home owners do not care for proper design of the basement at the time of construction and face tremendous problems later on. If care is taken initially, a lot of problems can be avoided.
Basement-Construction Questions (38)
4038
2205
2466
Retaining wall - Usage of Cement Plasticisers
Last answer on 7/23/2012 11:16:03 AM. by S L Gupta (Civil Engg). Forum started by George Kattapuram
1820
How to level up your WoW game level?
Last answer on 11/23/2021 11:33:21 PM. by Fox. Forum started by weridikka
12251
1980
Dear Sir,I need your advice on the new house, which I have recently booked and i
Last answer on 8/8/2014 10:57:40 AM. by Abhishek Vohra. Forum started by Esha
3607
18434
2253
Pillar construction
Last answer on 8/17/2013 11:06:12 AM. by S L Gupta (Civil Engg). Forum started by SCK
2783
Last answer on 7/5/2010 11:03:34 PM. by rump6767. Forum started by sourabh garbhe
1559
Dear sir,I have a plot of Size 28'X30'.it is 10' in depth.so please can i know t
Last answer on 4/14/2015 12:37:14 PM. by S L Gupta (Civil Engg). Forum started by thirumalesh
1632
GROUND WORK
Last answer on 9/23/2015 6:37:57 PM. by JAI PRAKASH. Forum started by sumit
1935
Please advise what should be the height of the ground level of stilth from the r
Last answer on 3/21/2014 7:54:36 AM. by ajaywahi. Forum started by ajaywahi
1576
Stilth to Road Height
Last answer on 3/18/2014 1:16:52 PM. by S L Gupta (Civil Engg). Forum started by ajaywahi
2583
Re. eccentric footing.
Last answer on 12/6/2013 12:11:41 PM. by S L Gupta (Civil Engg). Forum started by vignesh_mp
1794
Earth Filling
Last answer on 1/30/2014 10:54:38 AM. by Ahmed. Forum started by Ahmed
1699
How should be footing net for column adjacent to existing wall
Last answer on 6/3/2017 3:04:50 PM. by S L Gupta (Civil Engg). Forum started by Surinder Singh
2090
Foundation
3271
Roof Concrete Strength
9060
makan map
2774
17222
1993
2155
design of column
2251
Underground water tank
2657
2764
foundation
2032
Full Plan Needed
3195
labour cost
3163
APP membrane
2796
1969
ffff
1871
4209
Selection of cement ..
2016
Regarding construction
3154
Basement Water proffing
2014
Acid staining
Basement Design Ideas
Vastu Guidelines for Basement
Basement Ceiling
Basement Flooring
