Home -> Forums -> Construction -> Door Frames -> Which is the best protection coating/paint to be used inside and outside of wooden door frames for termite as well as general protection during home construction phase?
Fri Dec 16, 2016Total posts : 2
Topic: Which is the best protection coating/paint to be used inside and outside of wooden door frames for termite as well as general protection during home construction phase?
Which is the best protection coating/paint to be used inside and outside of wooden door frames for termite as well as general protection during home construction phase? I want to polish the door frames aftet construction as final.
Fri Dec 16, 2016Post  #1
I think paint is not good choice since I want polish as final finish. More worried about the suitable coating for out side of door frames, ie. In between brick and door frame, since it can't be changed or re-painted later..
Fri Dec 16, 2016Post  #2
Dear Vinu,
          The back of wooden chowket the portion adjoining with masonry should be painted with  two coat creosote, coal tar or any other wood preservative mixed with anti termite solution available in the market. the other 3 faces should be applied with priming coat.
For protection against water and splashing of cement mortar wood or plastic or polythene strips should be lightly nailed temporary on chowket face.
Door Frames -Construction Questions (32)
5223
1468
What is best method to clean GI Door frames after cement plaster is over. If har
Last answer on 7/4/2020 3:19:44 AM. by Surinder Singh. Forum started by Surinder Singh
5226
1965
5017
2669
2032
Last answer on 1/28/2011 10:11:15 AM. by Nikita. Forum started by gururaj s sannakki
2699
is running horse painting is bad inside home.
Last answer on 4/16/2012 11:27:40 AM. Forum started by sanjeev sharma
5312
Alternative materials for Modular Kitchen
Last answer on 7/27/2013 7:55:03 PM. by Pooja. Forum started by GULSHAN RAI GULATI
3219
2572
DOOR PVC OR WOODEN
Last answer on 7/3/2020 10:29:57 PM. by S L Gupta (Civil Engg). Forum started by SACHIN
1217
Sir i m planning for new house .. which wooden frame is best sal or teak or deod
Last answer on 8/16/2018 2:03:02 AM. by S L Gupta (Civil Engg). Forum started by Shivam gupta
2606
Window position on wall
114
Last answer on 1/30/2011 9:45:38 AM. Forum started by Girish
2731
2525
1692
3489
62
doubts regarding the purchase of wood....
Last answer on 3/14/2011 11:03:12 PM. by Dinesh Manaktala. Forum started by sangeetha
4735
3219
29139
wood calculation
Last answer on 1/5/2022 2:17:35 AM. by Navneet Jharia. Forum started by agg
2858
Column Size and distance
5017
1671
outside main gate
Last answer on 11/17/2020 12:09:44 PM. by S L Gupta (Civil Engg). Forum started by Pooja
4084
need little calcultaion
Last answer on 7/4/2020 12:03:17 AM. by JAI PRAKASH. Forum started by gaurav
2689
DOORS
10466
1889
door frame height
Last answer on 12/29/2015 12:49:44 AM. by JAI PRAKASH. Forum started by Pooja
2075
2981
Door window frame
Last answer on 12/16/2013 9:13:21 AM. by . Forum started by Purvi Panchal
3479
Last answer on 3/4/2013 6:35:55 PM. by S L Gupta (Civil Engg). Forum started by P. Panchal
Protection
Protection against Mosquitoes
A few diseases like Dengue and Chikungunya have resulted in expressions of confusion all around. These diseases are tr..
Termite Control
Termite
Termite Control
Have you protected your home from termites? Termites destroy household articles and create unhygienic conditions for i..
Which type of DPC recommended for the protection of dampness?
For residential buildings DPC consists of a layer of - 40 mm thick cement concrete 1:2:4 (1 cement: 2 Coarse sand: 4 g..
