Home -> Forums -> Construction -> Cement -> Which cement is better for RCC roof, PPC or PSC?
Wed Jan 11, 2017Total posts : 2
Topic: Which cement is better for RCC roof, PPC or PSC?
I am confused about whether to choose PPC or PSC cement for RCC roof....Planning to buy ultratech brand but which type to choose. Please suggest.
Thu Jan 12, 2017Post  #1
Dear Vinu,
For engineering purposes, there are many types of cement but in general, ‘Ordinary Portland Cement’ (OPC) which is available in three grades should be used for house construction
33 Grade Ordinary Portland Cement
This ordinary 'Portland' cement is used maximum in the country. It is more suitable cement for masonry and general concrete works where the members are not taken to very high stresses. It is not suitable where ‘Sulphate’ is in the soil or in the ground water.
43 Grade Ordinary Portland Cement
43 grades of cement are used where high early strength in 1 to 28 days range is required. These days the ‘Structural Engineers’ propose these cements mainly for RCC works where a member takes high tensile stress.
53 Grade Ordinary Portland Cement
53 grades of cement are used where high early strength in 1 to 28 days range is required. These days ‘Structural Engineers’ propose these cements mainly for RCC works, where a member takes high tensile stress.
Caution in the use of 53 grade cement in construction:
The strength of 53 grade cement does not increase much after 28th day because of early gain while 33 grade cement continues to gain strength after 28th day.
In addition, due to faster hydration process, the concrete releases heat of hydration at much faster rate initially and release of heat is the highest in case of 53 grades. The heat of hydration being higher, the chances of micro-cracking of concrete is much greater. Thus during initial setting period of concrete, the higher heat of hydration can lead to the damage of micro-cracking within the concrete which may not be visible at surface.
This cracking is different from shrinkage or cracks which occur due to faster dryness of concrete in windy conditions. The situation can be worse when we tend to increase the quantity of the cement in concrete with a belief that such increments are better for both strength and durability of concrete.
Thus it is very essential to be very careful in advance that higher grade cement specially GRADE 53 SHOULD be used only where such use is warranted for making the concrete of higher strength and also where good quality assurance measures are in place by which proper precautions are taken to relieve the higher heat of hydration through chilling of aggregates or by proper curing of concrete
Thu Jan 12, 2017Post  #2
Dear Vinu,
     See the link below which are very help full during construction.
2695
25607
CURING TIME FOR RCC ROOF
1923
4209
Selection of cement ..
13755
4365
WHAT IS THE RATIO
4647
1874
191897
2081
Last answer on 10/23/2010 3:33:17 PM. Forum started by sandeep Dholakia
2898
RCC Roof
2253
Hello members..i am building a small bungalow in Karjat .Mumbai.. and would like
Last answer on 1/27/2015 7:22:56 PM. by JAI PRAKASH. Forum started by FRANCO VAZ
3086
1457
1744
please let me know on the roof tile is better or marble is the better option . p
Last answer on 6/20/2016 11:35:02 PM. by Purvi Panchal. Forum started by Krishna
7005
3802
1669
Cement requirement
1785
RAW MATERIAL
3443
Type of Cement
2527
RCC Slab -Curing
2326
Materials
2872
Types of Cement
2515
Cement
2736
Per Square
Last answer on 6/23/2019 11:56:29 PM. by S L Gupta (Civil Engg). Forum started by kiran kumar 3k
1283
1989
Cracks in concrete roof
1241
Last answer on 5/26/2016 12:44:58 PM. Forum started by SUNIL KUMAR
1741
2265
Cement selection
1876
Economical cement brand
Last answer on 2/22/2015 7:02:19 PM. by Bhuwan. Forum started by Bhuwan
2903
Cost of Cement Plaster
1856
Last answer on 4/11/2014 2:04:43 PM. by S L Gupta (Civil Engg). Forum started by shaik khaja nayab rasool
2484
Cement and Grades
Last answer on 6/13/2013 2:45:08 PM. by S L Gupta (Civil Engg). Forum started by MANJUNATH
3040
2436
Past Prices
Last answer on 11/23/2011 10:23:47 AM. by ravi at Dalmia. Forum started by Hemanth
Cooper
