Is the concrete mix ratio M20 (1:1.5:3) weight based? If yes, whether volume based 1:2:4 ratio is almost equal to M20?
Thu Mar 09, 2017Total posts : 1
Topic: Is the concrete mix ratio M20 (1:1.5:3) weight based? If yes, whether volume based 1:2:4 ratio is almost equal to M20?
Fri Mar 10, 2017Post  #1
Dear Vinu,
           There is not much difference in weight and volume as concerned the ratio. These both are not same.
2492
Used M15 (1:2:4) mix ratio with PPC cement for casting ground floor house roof slab
Last answer on 2/21/2017 12:28:02 PM. by S L Gupta (Civil Engg). Forum started by vinu
1763
1457
3791
3767
2414
roof concrete
2413
4365
WHAT IS THE RATIO
2690
Want to know the Strength of the Roof Slab
Last answer on 3/8/2011 5:41:21 PM. by S L Gupta (Civil Engg). Forum started by Sambasiva Rao Ravuri
11586
1717
CONCRETE MIX
Last answer on 7/3/2020 9:36:11 PM. by M Prabhu. Forum started by M Prabhu
2676
2062
cement : sand:stone ratio
2660
Last answer on 2/24/2022 11:54:36 AM. by S L Gupta (Civil Engg). Forum started by KUMAR RISHABH GIRIRAJ
1524
MIX PROPORTION
Last answer on 5/13/2016 10:51:18 AM. by S L Gupta (Civil Engg). Forum started by ANKITA MADA
2141
My data of birth is 22.11.1974 7.05 Am.based on my date of birth, which is suita
Last answer on 7/3/2020 11:46:46 PM. by S L Gupta (Civil Engg). Forum started by venkatanarayana
1809
what re these in gharexpert estimates
Last answer on 12/17/2015 2:57:41 PM. by JAI PRAKASH. Forum started by sushantsah
2535
Civil Eng Stair Design
Concrete Mix Ratio
Ready
Ready Mix Concrete
Paint
What preparations for base are recommended for terrazzo tiles flooring?
Preparation for base:- It is one of the most important steps to satisfy the tile installation. Sub flooring should be ..
What is acre
Cement
Cement Concrete
