Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> construction
Sat Aug 24, 2013Total posts : 1
ragha
ragha
Topic: construction
Hello Sir,
Thank you sir.
I tried using the estimator,but i could not find the RCC pillar section.
As of now i have little funds...so is it possible to at least start with the RCC pillars and roof for an area of 30*50.
May be 1 or 2 years later i will plan for the actual house on the roof.
regards
ragha
I have a 40*60 site in my village and am planning to build a g+2 floor house.
For now i want to complete basement i.e pillars and roof.
basement is @ ground level and will be used for parking.
i would be leaving 5 feet clearance on all 4 sides...so the construction
area would 30*50.
I want to know the basic cost of this work i.e just earth work for pillars,pillars,beams and the roof in terms of cement required,steel required, labour cost....
Pls assume the pillar,roof thickness, dimension to be standard residential purpose as am not very clear on the dimension to be used.
regards
ragha
Mon Aug 26, 2013Post  #1
Dear Ragha
             In the estimator, we can find the rough cost estimate and the size of column etc.
For size of columns and other structure you should consult plan of the building and structural drawing.
According to fund you can start the construction work as you like.
For estimation drawing and specification is necessary.
Brick Walls, Pillars and Structure-Construction Questions (40)
23866
6099
What is construction cost
3089
2019
2299
1871
1783
1740
5793
Last answer on 8/20/2020 3:44:33 AM. by S L Gupta (Civil Engg). Forum started by mayank
2353
2193
4949
3879
6464
2224
1894
give me the detailed inner construction plan...
Last answer on 5/12/2014 12:40:44 PM. by S L Gupta (Civil Engg). Forum started by nilesh agrawal
2115
please,give me the full construction plan...
Last answer on 5/12/2014 12:39:42 PM. by S L Gupta (Civil Engg). Forum started by nilesh agrawal
4807
3574
construction current rate
5811
3792
9885
2670
4628
4143
2865
5006
3656
1865
2800
2610
2373
2462
2638
1807
3608
6254
