Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> construction
Fri Aug 23, 2013Total posts : 1
ragha
ragha
Topic: construction
I have a 40*60 site in my village and am planning to build a g+2 floor house.
For now i want to complete basement i.e pillars and roof.
basement is @ ground level and will be used for parking.
i would be leaving 5 feet clearance on all 4 sides...so the construction
area would 30*50.
I want to know the basic cost of this work i.e just earth work for pillars,pillars,beams and the roof in terms of cement required,steel required, labour cost....
Pls assume the pillar,roof thickness, dimension to be standard residential purpose as am not very clear on the dimension to be used.
regards
ragha
Sat Aug 24, 2013Post  #1
Dear Ragha
          The cost estimate will be give after the plan of the building, first final your building plan and specification to be used in construction. If you want rough cost estimate than use Estimator given in the gharexpert.com website. Link given below
http://www.gharexpert.com/Estimator/Startpage.aspx
23872
6101
What is construction cost
3095
2024
2303
1876
1789
1746
5798
Last answer on 8/20/2020 3:44:33 AM. by S L Gupta (Civil Engg). Forum started by mayank
2358
3889
2199
4962
6467
2791
pl tell a good bookwhich can help in construction.thanks
Last answer on 12/4/2014 12:54:02 AM. by JAI PRAKASH. Forum started by DR GOEL
4261
3401
Bathroom Cleaning Tips
2404
Last answer on 1/17/2011 3:46:45 PM. by Swati Sharma. Forum started by pankaj singh
2743
i need.s windows aluminium with gllas & fire doors pvc construction in india l
Last answer on 2/24/2022 1:02:52 AM. Forum started by muhammad mansoor
4080
5817
3799
9892
2674
4631
4147
2870
5218
5020
3664
4068
1868
2803
2613
2384
2470
2641
1811
6260
