Home -> Forums -> Construction -> Door Frames -> door frame height
door frame height
Mon Dec 28, 2015Total posts : 2
Pooja
Pooja
Topic: door frame height
Hello,
How much height of door frame should be used when total height from floor to ceiling is 11 feet?
Cheap and best termite resistent wood?
Mon Dec 28, 2015Post  #1
Dear Pooja\
          The door frame height should be from 6'-9'' to 7'.
Tue Dec 29, 2015Post  #2
Clear height should be at least 6.5 feet after floor work, you can dig inside the floor up to 3 to 6 inches.
Door Frames -Construction Questions (32)
5226
2846
Can u pls send me price for upvc door and door frame.Thomas
Last answer on 7/4/2020 3:07:03 AM. Forum started by Thomas Rodrigues
4084
need little calcultaion
Last answer on 7/4/2020 12:03:17 AM. by JAI PRAKASH. Forum started by gaurav
5017
2531
i want modren designs of main door frames.please sent the images to prashanthkum
Last answer on 11/18/2013 4:12:52 PM. by S L Gupta (Civil Engg). Forum started by kiranmai.a
2669
2123
Can i get the detail of Manufacture or Dealer of Aluminium Door Frame with door.
Last answer on 1/20/2021 8:26:43 AM. by jyoti. Forum started by Vijay Chikhalikar
3489
2572
DOOR PVC OR WOODEN
Last answer on 7/3/2020 10:29:57 PM. by S L Gupta (Civil Engg). Forum started by SACHIN
3269
Door Frames
Last answer on 10/22/2010 12:50:15 PM. by Mohammed Moin. Forum started by Mohammed Moin
2492
jaisalmer /sandstone use
Last answer on 9/8/2010 11:42:16 AM. by S L Gupta (Civil Engg). Forum started by geetanjali nitave
3033
What is the checklist for wooden doors?
Last answer on 3/13/2010 8:35:00 PM. by K Anjaneyulu. Forum started by vijaykumar
5288
if anybody have good main door frame models pics?,prefer rectagle model size 210
Last answer on 8/9/2013 10:15:39 AM. by GUNA. Forum started by rense
2718
3219
5223
1965
2986
how many type(colour)s sal wood is there . which is good for making frames for d
Last answer on 6/25/2014 1:38:01 PM. by S L Gupta (Civil Engg). Forum started by sathish
29139
wood calculation
Last answer on 1/5/2022 2:17:35 AM. by Navneet Jharia. Forum started by agg
4735
3219
29139
wood calculation
2858
Column Size and distance
5017
1671
outside main gate
Last answer on 11/17/2020 12:09:44 PM. by S L Gupta (Civil Engg). Forum started by Pooja
4084
2689
DOORS
10466
1733
2075
2981
Door window frame
Last answer on 12/16/2013 9:13:21 AM. by . Forum started by Purvi Panchal
3479
Last answer on 3/4/2013 6:35:55 PM. by S L Gupta (Civil Engg). Forum started by P. Panchal
Door
Door and Window Frames
Teak
Teak wood frame
Advantages
Which are various types of frames for Aluminium doors?
Frames for Aluminium doors-STEEL FRAME , METAL FRAME , FRAME WITH HIGHLIGHT, METAL DOOR FRAME.......
