Bricks
Thu Nov 05, 2015
Techman
Topic: Is home made concrete bricks safe?
I'm in search for good quality concrete bricks for the load bearing walls of my two storey house.
The brick manufacturing units in our local market produce bricks using big hydraulic press and concrete mixers where we are not sure about the quality/quantity of raw materials used, and also no written guarantee on quality or other strength specifications.
Some contractors bring small hand operated brick making machine to our site and we have to supply the raw materials.
So, I prefer second option, but also would like to know the quality difference in using big hydraulic press and small hand operated press for making concrete bricks. Does more compression makes the bricks more strong?
Thu Nov 05, 2015
Dear Tachman
For this problem you should Take 3to4 sample bricks from both the sources of supply and get tested for compressive strength and result give about the best.
Thu Nov 05, 2015
Techman
Sir, here compression test costs around 2000/- per piece... So, just want to get general opinion from professionals with experience...
Fri Nov 06, 2015
It can not be finalized without a test.
3456
Last answer on 9/17/2012 8:35:35 PM. by
piyush
Kinley Tshering
2992
3433
amit yadav
amit yadav
2024
1810
Last answer on 5/3/2016 12:15:59 AM. by
Rajput veer pratap singh
191901
Last answer on 1/23/2022 3:32:01 AM. by
Bimlendra Jha
3470
Cost of concrete walls
Ar. Manoj Ralen
Ankur Kothari
4179
GLASS BLOCKS / BRICKS
Last answer on 11/10/2021 8:22:17 PM. by
Girish
Girish
2584
Last answer on 7/4/2020 2:41:58 AM. by
pradeep kapoor
2244
how many steps made at home.
Last answer on 7/4/2012 8:11:12 AM. by
Saurabh
1889
I have a piece of land 25'width/50'length.Pls. suggest me for home making archit
Last answer on 2/19/2019 11:23:49 PM. by
Saurav anand
ashish panchal
2523
404
flooring
Last answer on 12/18/2010 12:30:53 PM. by
ali
1682
earthquake safe building
Last answer on 5/12/2015 2:55:33 AM. by
ARVIND GOYAL
3237
Last answer on 9/24/2014 11:34:03 AM. by
somasekhar
6471
Last answer on 4/5/2018 12:39:19 AM. by
Sanzana Hosen
1067
Last answer on 7/4/2020 3:50:38 AM. by
Surinder Singh
3081
Last answer on 2/25/2014 6:35:09 AM. by
manish
jagminder
7513
Brick Advice Urgent
pmarple
pmarple
2879
Bricks
Chandrasekaran S
2793
brick calculation
Last answer on 4/14/2021 6:20:51 PM. by
Gagandeep
2565
Cost of Brickwork
Last answer on 12/31/2020 2:51:43 AM. by
Abhijeet Shinde
4894
Last answer on 8/29/2020 12:29:33 PM. by
Kalayart
Vishal Thakur
2821
srinu
2350
Vikas
3172
bricks
Last answer on 7/3/2020 11:33:47 PM. by
drkksuresh
drkksuresh
5658
Last answer on 7/3/2020 10:43:26 PM. by
sunny420
Last answer on 7/3/2020 9:20:34 PM. by
Alfred
Akshay
3238
Last answer on 6/19/2019 10:21:22 PM. by
Sanzana Hosen
5135
Use of Solid Concrete Bricks
aravind
Kinley Tshering
1624
Last answer on 1/20/2017 3:47:17 PM. by
1341
Last answer on 1/16/2017 3:05:19 PM. by
1845
Last answer on 11/3/2016 2:26:29 PM. by
1479
Last answer on 8/24/2016 12:13:52 PM. by
1797
2966
fly ash bricks
Last answer on 5/26/2016 3:10:41 PM. by
santhosh
2230
Last answer on 5/3/2016 12:34:16 AM. by
sayeedmohsin
1723
Techman
Concrete Mix Ratio
Various Types of Bricks
Concrete Decor
How to Design Patio Floor
The patio flooring you choose should be appealing, easy to maintain and durable. Attractive design of patio flooring i..
