Home -> Forums -> Construction -> Start Construction -> Is it ok to fix wooden door frames after construction of house to avoid damage?
Fri Dec 16, 2016Total posts : 1
Topic: Is it ok to fix wooden door frames after construction of house to avoid damage?
My contractor told me that fixing wooden door frames after the construction of wall and rcc roof but before the plastering work will save it from possible damages during construction phase. But some others of the opinion that fixing door frames at the initial stage of construction is easy and will give good finish. So, please help. Is there any drawback in fixing door frames after the wall and roof construction?
Sat Dec 17, 2016Post  #1
Dear Vinu,
        In my  view and the general practice door and window frame should be fixed simultaneously with the wall masonry. It will give good bonding of frame with wall. See
We are discussing about frames of doors and windows. First we will discuss about door frames. A door is a solid barrier i.e. fixed in the opening of a wall. It can be opened for access to and from buildings and between the rooms or closed for privacy. The door has two parts: one part is frame and second part is shutters. The classification of door frames according to material is
1. Wooden door frame
2. Aluminum door frame
3. Iron door frame
Wooden door frame
Wood is the most popular choice for construction of door and window frames. Wooden frames give architectural beauty to the building and are easy to maintain. There are many types of wood according to the quality. The type of wood is used according to the requirement of the building and availability of budget.
  • Timber is sawn in the direction of grains.
  • All members of frames are of same species of timber and be straight without any warp.
  • The frames are smooth, well planed surfaces except the surface touching wall lintel sill etc.
  • The rebate is done before members are joined into frame.
  • The thickness of rebate is 15 mm and the width is equal to the thickness of shutter.
  • If wire gauze shutter is to be fixed, two numbers of rebate should be made.
  • A door frame consisting of three wooden members i.e. two upright posts called jamb posts, which are jointed with top piece called cross piece or head.
  • Nominal size of door frame for single shutter is 75 MM X100 MM and for double shutter 75 mm X 125 mm.
  • The door frame is jointed with mortise and Tenon joints as this joint is the strongest one.
  • The length of jammed post/vertical post should have extra length of 40 mm from door opening for embedding it into the floor.
  • The top corner of the frames is secured with G. I. sheet and iron screws.
  • The back portion of door frame which in contact with walls, lintels sill etc. is painted with bitumen or any anti-termite chemical.
  • Each prepared door frame is fitted with temporary stretcher at bottom to keep the frame in position.
  • The frame is in true to right angle.
  • To protect door frame during construction priming coat is done before fixing.
  • (This Picture is Contributed by "Ahmed")
    A nice wooden door frame.
    Aluminum Door Frames
    Now a days aluminum door and window frames are mostly used in commercial and offices complex, high class buildings to give architectural view to enhance the beauty and smooth working. These frames give beautiful looks, require no painting and less maintenance cost and are free from termite attack, rusting problems etc.
    • The door frames are mostly in use after 1990.
    • These should be manufactured from reputed manufacturer.
    • Aluminum door window frames should be according to IS: 1948 and I S: 1949 on manufacturing.
    • Generally size of aluminum door frame available in the market is as given below.
  • The Size = 44.4 X29 MM. 42.9 X 29 MM
    Aluminium Door Frame - very solid.
    Iron Frame
    Iron frames in door and windows are used in low cost buildings. These frames are safe from termite attack. There are three types of iron door frames.
    1. Angle iron door frame
      These door frames are made from angle iron of size 40 mmX40 mmX6 mm. Iron hinges are welded with frame. The joints should be flush welded and ground smooth with grinder. The frame should be true to right angle. Priming coat should be done before fixing the frame.
    2. T. Iron door frame
      These frames are made from T. Iron and all other procedure is the same as for angle iron door fame.
    3.
    4. Pressed steel door frames
      These frames are manufactured from mild steel sheet 1.25 mm thickness. Iron hinges are welded with frame. The length of vertical post should be 40 mm extra long as compared to opening for embedding in the floor. The joints should be flush welded and grinded smooth with grinder. The back side of frame is filled with cement concrete 1:3:6 before fixing. Priming coat is done before fixing. The size of pressed steel door frame = 89 X 50 MM, 76 X 38 MM, 127 X50 MM, 114 X 50 MM available in the marke
    Window Frame
    In this section we will discuss about window frames. Window is an opening into the wall for providing daylight, ventilation and to view outside look. It has two parts: one is window frame and the other is shutters. All other specifications of window frame are the same as for door frames given above.
    Fixing of Door and Window Frames
    • Frames are fixed in opening abutting masonry or concrete with iron hold fast.
    • Hold fasts are embedded in cement concrete block 1:3:6 ratios in the masonry walls.
    • While fixing frames it should be in plumb, level and in straight line.
    • Door and window frames can be fixed in masonry either at the time when work is in progress or in the opening left in masonry for fixing frames.
    • Vertical members of door frames are embedded in the floor for full thickness of floor finish.
    Small size wooden window frame
    Bedroom with big size wooden window for a bigger view...just amazing!
    Spacing for Fixing Hold Fasts
    The spacing recommended for fixing hold fasts vary for different types of frames.
    1. For wooden frame: Minimum three hold fasts are fixed on each side of door frames; one at the center point and the other two at 30 cm from the top and the bottom of the frame.
    2. For M.S. steel frame: Three lugs /hold fasts are provided on each jamb spacing not more than 75 cm.
    3. For aluminum door frame: In aluminum door frames, the frame is fixed with four numbers of lugs/hold fast as given below.
    • First number at 45 cm from the bottom.
    • The second number at 109 cm from the bottom.
    • The third at 139 cm from bottom.
    5226
    2669
    5017
    2572
    DOOR PVC OR WOODEN
    Last answer on 7/3/2020 10:29:57 PM. by S L Gupta (Civil Engg). Forum started by SACHIN
    3219
    2731
    2525
    3597
    4107
    2689
    DOORS
    2490
    is these lights fixed inside the wooden boxes?
    Last answer on 3/3/2011 9:03:23 PM. by Nenni. Forum started by meenu
    1684
    Last answer on 10/7/2014 11:37:58 AM. by S L Gupta (Civil Engg). Forum started by SANJAY DUSANE
    2050
    1217
    Sir i m planning for new house .. which wooden frame is best sal or teak or deod
    Last answer on 8/16/2018 2:03:02 AM. by S L Gupta (Civil Engg). Forum started by Shivam gupta
    62
    doubts regarding the purchase of wood....
    Last answer on 3/14/2011 11:03:12 PM. by Dinesh Manaktala. Forum started by sangeetha
    2034
    I have 5 galloping horses frame on my north wall of house .is that ok.if no then
    Last answer on 12/30/2014 10:57:03 AM. by seema tyagi. Forum started by Darshana
    1733
    3269
    Door Frames
    Last answer on 10/22/2010 12:50:15 PM. by Mohammed Moin. Forum started by Mohammed Moin
    1965
    3310
    2133
    2059
    Termite
    Termite Damage Signs and repairing tips
    Termite damage is a worst dream for any house owner. Termites eat wood and this affect almost every wooden product lik..
    Door
    Protect
    Protect Your Family from Dust
    Teak
    Teak wood frame
    Why
