Is it possible to fix compound wall iron gate weighing around 150kg on a 8"x8" r
Fri Dec 14, 2018Total posts : 1
Topic: Is it possible to fix compound wall iron gate weighing around 150kg on a 8"x8" r
Is it possible to fix compound wall iron gate weighing around 150kg on a 8"x8" rcc pillar? We can not give extra width for pillar footing due to space limitations. If possible please also tell me how deep the pillar must go below the ground level.
Sat Dec 15, 2018Post  #1
       You can increase the size of pillar or column on length wise and keep it 8'' on width wise. put 6-8 MS Steel bars in the pillar with Rings @ 6'' center to center.
    Keep the foundation 3 feet in hard soil. Keep the length of  hold fast 12'' to 15''.
     Thanks.
1880
main gate
Last answer on 6/16/2015 4:45:50 AM. by JAI PRAKASH. Forum started by ARVIND GOYAL
2481
images of iron gate attached to main door
Last answer on 11/18/2013 4:05:44 PM. by S L Gupta (Civil Engg). Forum started by nagaraja k.n.
835
6228
1802
3251
compound wall
1487
5154
2379
Sir i am sundar,i have 30'*54' area.i want to vasthu plan for south face entranc
Last answer on 11/14/2012 2:16:29 PM. by Gunjan Utraja. Forum started by SUNDAR
2322
4090
1687
2390
2237
Sreel pillars(post)
3636
Compound Wall
3853
Compound Wall Construction
13636
2823
272
81
29
26
31
31
30
28
28
29
25
25
21
31
22
30
27
23
Basic
Basic home security tips
Door
Door and Window Frames
Canvas
Canvas Wall Art
Wrought
Wrought Iron Furniture
Wrought iron furniture is perfect blend of art and beauty. It’s one of the most popular choices of service providers a..
Iron
Iron Sheet Roofing
Wall
Wall Decor
