labor rate for RCC work
Sat Mar 29, 2014Total posts : 2
ringwang
ringwang
Topic: labor rate for RCC work
Please kindly help me to decide the labor rate of R.C.C beam and slab for my project.
Work detail
Beam size 3.5’ X1.5’ X 80’
Slab:  44’X80’
The height of building is 43’ level.
Our contractor Rate as below
Beam: 450rs/sqft
Slab: 350rs/sqft.
What is the current basic rate for
Centering /shuttering
Reinforcement  25mm 20mm and  12mm  for stirrup.
Slab : 8mm dia for two way slab
Also Beam and slab concreting?
Attachments: detail work.xlsx on Sat Mar 29, 2014,&n
Mon Mar 31, 2014Post  #1
      The rates can be verified for normal work. It is at 43 feet height and extra  support is required according to site situation and four or five time supports is needed. so cannot be verified.
Tue Apr 08, 2014Post  #2
ringwang
ringwang
Post subject: thank you.
thank you for your respond,
labour rate
3475
labour charges rates
35210
7835
Rcc staircase rates
Last answer on 3/18/2016 4:13:47 PM. by S L Gupta (Civil Engg). Forum started by Shabbir shaikh
2797
3651
11587
2420
Paint
Last answer on 6/11/2019 1:36:44 AM. by S L Gupta (Civil Engg). Forum started by mahender
2421
2603
Anyone having payment terms for labour contract for house
Last answer on 12/15/2015 12:57:03 PM. by S L Gupta (Civil Engg). Forum started by sushantsah
13784
rcc rate per cubic meter
Last answer on 10/20/2014 12:03:29 PM. by S L Gupta (Civil Engg). Forum started by anks
3196
labour cost
3574
construction current rate
1369
what is the standard labour outputs for different work in is code
Last answer on 7/4/2020 4:30:08 AM. by S L Gupta (Civil Engg). Forum started by santosh pore
3925
2525
3415
SOR
Last answer on 12/30/2021 10:26:27 AM. by S L Gupta (Civil Engg). Forum started by navneet
3614
if i fix some labour rate with petty contractor of covered area of building wit
Last answer on 12/29/2010 12:36:10 PM. by S L Gupta (Civil Engg). Forum started by sudhir singh
42598
Labour Cost for Roof RCC work
