Bricks
Thu Nov 03, 2016
Topic: labour for 140ft × 5ft boundary wall using 12x8x6" solid concrete bricks
Rubble foundation and concreting already completed. I just need the approx. labour numbers and labour cost for brick work only...not including plastering...
Howmany bricks can a main labour complete per day?
Thu Nov 03, 2016
Dear Vinu,
The labor cost of constructing the boundary wall is from Rs 15-00 per cft approximately.
2144
2514
3825
Last answer on 6/16/2015 4:28:50 AM. by
aladin
1331
Last answer on 1/16/2017 3:05:19 PM. by
2404
COSTING AND STRENGTH OF WALL
Last answer on 1/23/2016 8:45:03 PM. by
BYJU
3049
Last answer on 2/25/2014 6:35:09 AM. by
manish
jagminder
3443
Last answer on 9/17/2012 8:35:35 PM. by
piyush
Kinley Tshering
2949
3463
Cost of concrete walls
Ar. Manoj Ralen
Ankur Kothari
3657
wals
shabbir ali
9180
Vinod
2453
Last answer on 11/17/2015 8:51:17 PM. by
Techman
3134
Last answer on 8/16/2013 1:12:41 PM. by
K S SHYAM SUNDER
5123
Use of Solid Concrete Bricks
aravind
Kinley Tshering
3418
amit yadav
amit yadav
2822
Compound Wall Construction
Last answer on 11/20/2012 3:25:21 PM. Forum started by
honnappabr
13636
Last answer on 1/18/2022 1:46:41 PM. by
Bronx
honnappabr
1717
Last answer on 11/6/2015 12:41:03 AM. by
Techman
7496
Brick Advice Urgent
pmarple
pmarple
2852
Bricks
Chandrasekaran S
2785
brick calculation
Last answer on 4/14/2021 6:20:51 PM. by
Gagandeep
2555
Cost of Brickwork
Last answer on 12/31/2020 2:51:43 AM. by
Abhijeet Shinde
4881
Last answer on 8/29/2020 12:29:33 PM. by
Kalayart
Vishal Thakur
2809
srinu
2339
Vikas
3162
bricks
Last answer on 7/3/2020 11:33:47 PM. by
drkksuresh
drkksuresh
5630
Last answer on 7/3/2020 10:43:26 PM. by
sunny420
2001
Last answer on 7/3/2020 9:20:34 PM. by
Alfred
Akshay
3209
Last answer on 6/19/2019 10:21:22 PM. by
Sanzana Hosen
5123
aravind
Kinley Tshering
1614
Last answer on 1/20/2017 3:47:17 PM. by
1331
1470
Last answer on 8/24/2016 12:13:52 PM. by
1781
2956
fly ash bricks
Last answer on 5/26/2016 3:10:41 PM. by
santhosh
2193
Last answer on 5/3/2016 12:34:16 AM. by
sayeedmohsin
1713
Techman
