Bricks
Thu Nov 03, 2016
Topic: labour for 140ft × 5ft boundary wall using 12x8x6" solid concrete bricks
Rubble foundation and concreting already completed. I just need the approx. labour numbers and labour cost for brick work only...not including plastering...
Howmany bricks can a main labour complete per day?
Thu Nov 03, 2016
Dear Vinu,
The labor cost of constructing the boundary wall is from Rs 15-00 per cft approximately.
2523
3842
Last answer on 6/16/2015 4:28:50 AM. by
aladin
1341
Last answer on 1/16/2017 3:05:19 PM. by
2414
COSTING AND STRENGTH OF WALL
Last answer on 1/23/2016 8:45:03 PM. by
BYJU
2992
3081
Last answer on 2/25/2014 6:35:09 AM. by
manish
jagminder
3456
Last answer on 9/17/2012 8:35:35 PM. by
piyush
Kinley Tshering
3470
Cost of concrete walls
Ar. Manoj Ralen
Ankur Kothari
3669
wals
shabbir ali
9196
Vinod
2466
Last answer on 11/17/2015 8:51:17 PM. by
Techman
3145
Last answer on 8/16/2013 1:12:41 PM. by
K S SHYAM SUNDER
5135
Use of Solid Concrete Bricks
aravind
Kinley Tshering
3433
amit yadav
amit yadav
2836
Compound Wall Construction
Last answer on 11/20/2012 3:25:21 PM. Forum started by
honnappabr
13651
Last answer on 1/18/2022 1:46:41 PM. by
Bronx
honnappabr
2025
1728
Last answer on 11/6/2015 12:41:03 AM. by
Techman
7513
Brick Advice Urgent
pmarple
pmarple
2879
Bricks
Chandrasekaran S
2793
brick calculation
Last answer on 4/14/2021 6:20:51 PM. by
Gagandeep
2565
Cost of Brickwork
Last answer on 12/31/2020 2:51:43 AM. by
Abhijeet Shinde
4894
Last answer on 8/29/2020 12:29:33 PM. by
Kalayart
Vishal Thakur
2821
srinu
2350
Vikas
3172
bricks
Last answer on 7/3/2020 11:33:47 PM. by
drkksuresh
drkksuresh
5658
Last answer on 7/3/2020 10:43:26 PM. by
sunny420
Last answer on 7/3/2020 9:20:34 PM. by
Alfred
Akshay
3238
Last answer on 6/19/2019 10:21:22 PM. by
Sanzana Hosen
5135
aravind
Kinley Tshering
1624
Last answer on 1/20/2017 3:47:17 PM. by
1341
1479
Last answer on 8/24/2016 12:13:52 PM. by
1797
2966
fly ash bricks
Last answer on 5/26/2016 3:10:41 PM. by
santhosh
2230
Last answer on 5/3/2016 12:34:16 AM. by
sayeedmohsin
1723
Techman
