Home -> Forums -> Construction -> Brick work -> How many wire-cut clay bricks are required for 68 cubic meter wall?
Tue Sep 13, 2016Total posts : 1
Topic: How many wire-cut clay bricks are required for 68 cubic meter wall?
The material estimation of proposed house plan shows the brick requirement as 68 cubic meter instead of in numbers. So, please help me to convert the same into numbers.
Tue Sep 13, 2016Post  #1
Dear Vinu
       The numbers of bricks required for 68 cum= 30000nos
2865
1800
3007
13805
rcc rate per cubic meter
Last answer on 10/20/2014 12:03:29 PM. by S L Gupta (Civil Engg). Forum started by anks
Simple way for explain Cubic meter
Last answer on 2/18/2011 11:29:37 PM. Forum started by KS T9
3656
1650
Road Construction
Last answer on 9/13/2016 3:04:32 PM. by S L Gupta (Civil Engg). Forum started by Bharat Kumar
2875
FLYASH OR CLAY BRICK
1343
5016
3083
How much time curing is required for bricks wall.
Last answer on 6/17/2016 12:45:17 PM. by S L Gupta (Civil Engg). Forum started by MANISH
2885
Bricks
1828
foundation
Last answer on 10/5/2014 1:20:44 PM. by SANJAY DUSANE. Forum started by nitu
2098
Red Exposed Brick
Last answer on 12/8/2014 10:03:59 PM. by JAI PRAKASH. Forum started by awdhesh
1981
Transport
Last answer on 4/2/2016 12:12:42 PM. by S L Gupta (Civil Engg). Forum started by Bunkera1993
1866
Last answer on 1/5/2022 9:14:05 PM. by sanjay agarwal. Forum started by saradha
1654
Last answer on 7/3/2015 3:57:17 AM. by JAI PRAKASH. Forum started by sandeep yadav
8823
Last answer on 7/3/2020 10:16:59 PM. by JAI PRAKASH. Forum started by sandeep yadav
3673
wals
3267
compound wall
21903
3283
Bedroom Wardrobes information
2248
2211
1500
1971
1734
2228
2528
1506
1913
Brick or ACC block
2154
1708
4716
Brick wall on RCC slab
3935
2623
Various Types of Bricks
What is binding wire
Electrical
Electric
Electric Shock Proof Home
