Home -> Forums -> Construction -> Finishing -> need advice
Thu Feb 04, 2016Total posts : 8
raj
raj
Topic: need advice
Plastering of my newly constructed 1st floor is about to start. Your earlier advice on raw material were very informative and accurate. Thanks again. Now, I want to have your view on the
1. ratio of cement to sand for plastering interior and exterior walls,
2. Water proofing treatment to be done. Will only adding Dr. Fixit will cater the        need or what else is to be done. Please also inform the ratio of Water                  proofing additive.
3. I want to paint the wall after monsoon & before deepawali. Till then, how the walls(internal and external) should be treated, i.e. white cement or POP.
Your valuable advice at earliest shall be highly appreciated.
with regards,
Fri Feb 05, 2016Post  #1
Dear Raj
        The ratio of cement sand should be 1:4. About water proofing you can use Dr. fixit and use according to the instruction printed on the water proofing material.
You can apply priming coat in advance.
Fri Feb 05, 2016Post  #2
raj
raj
Thanks Gupta Sir for your prompt valuable advice. Sir will you please elaborate on priming coat i.e. material /brand etc.
Fri Feb 05, 2016Post  #3
Dear Raj,
1. plaster ratio 1:4 ( Sri Guptaji is correct )
2. Dr fixit is enough, if the slope is proper.
3. use wall putty 2 coats
Sun Feb 07, 2016Post  #4
Ratio is 4:1
Dr. Fixit as per instructions
Use POP on internal walls, Then Putty primer and final paint. Only Birla white on external walls then paint.
Mon Feb 08, 2016Post  #5
The preparation of a surface is 90 percent of painting job. Even the highest quality paint won’t adhere properly if the underlying surface is not prepared properly. Good surface preparation means clean and smooth surface.
Tips for Surface Preparation
  • Allow newly plastered surface to mature for a period of at least 6 months before painting.
  •  Rectify existing surface problems such as dampness, cracks etc. before actual painting process.
  • Check for hand prints, greasy fingerprints, algae as well as dirt and stained marks.
  • Use a scraper, putty knife or scrub brush to remove any dirt, grease, rust, or flaking.
  • Fill in the holes, cracks and joints with plaster.
  • Clean and dry the surface.
  • Make sure the area to be painted is well ventilated as well as free of dust.
  • As far as possible, don’t paint under much humid conditions.
Do before starting painting work
  • Remove materials such as light fixtures, curtains and their rods etc. from the room to protect them paint splashes. The materials which cannot be removed out should be placed at the center and be covered with a canvas or plastic sheet.
  • Place a large bin with a plastic bag to gather debris or paint splashes. A dirty work place is not only unsafe but can slow the process of painting also. Also make use of canvas to cover the floor to avoid paint splashes.
  • Insert nails and hooks for pictures. Fill the holes made by nails with plaster and sand before painting again.
  • Use painter’s tape to cover up the area that you do not want to paint. Also do the same for doors, windows and ceilings that you can not remove.
Tue Feb 09, 2016Post  #6
Allenmaxwell
Allenmaxwell
thanks it will help for me.
Wed Feb 10, 2016Post  #7
raj
raj
Thanks Guptaji, Purvi & Jai Prakash for your valuable guidance.
Sat Mar 05, 2016Post  #8
You are welcome Raj.
Finishing-Construction Questions (36)
2674
Termite Treatment
Last answer on 9/25/2020 2:58:44 AM. by S L Gupta (Civil Engg). Forum started by Hidayath
2188
6451
Need advice to remove the visible beam in bedroom area
Last answer on 7/3/2020 9:58:37 PM. by Bipin Puri. Forum started by mavi
1803
Need Advice on Solid Wood Floors
Last answer on 4/30/2014 8:29:12 PM. by Abhishek Garg (Builder & Engineer). Forum started by chintan arora
7045
Need Advice regarding Coconut Tree inside the Compound
Last answer on 1/4/2015 12:27:12 PM. by satish. Forum started by Abhi
1788
Dear sir/madami am building a house in coastal part of goa.need advice from expe
Last answer on 10/11/2015 8:43:58 PM. by JAI PRAKASH. Forum started by prasad K
1369
Need advice for constructing commercial building with a pent house
Last answer on 9/9/2016 11:42:58 PM. by bhuvaneshwaran bn. Forum started by Mini
2764
Question on kitchen platform and sink
Last answer on 7/4/2020 2:15:45 AM. by Clarence James. Forum started by VijiRaghavan
3013
Last answer on 11/27/2012 9:08:57 AM. by VijiRaghavan. Forum started by VijiRaghavan
1866
Hall Room Repair
Last answer on 4/15/2013 12:24:33 PM. by S L Gupta (Civil Engg). Forum started by Zaman
2769
Compound wall construction
Last answer on 11/5/2014 9:02:10 PM. by SANJAY DUSANE. Forum started by Mahesh
1834
Hi ,I need to build compound wall for area of 12ft high and 40ft length 9 inches
Last answer on 11/3/2014 11:39:50 AM. by S L Gupta (Civil Engg). Forum started by Mahesh
1931
need help/advice to construct residentail house on 100 sq yd plot in hyderabad
Last answer on 2/21/2017 12:44:08 PM. by S L Gupta (Civil Engg). Forum started by Kamal
1648
Design Layout for Shops and Flats
Last answer on 5/10/2016 11:43:26 AM. by S L Gupta (Civil Engg). Forum started by Amir Rehman
6651
Sliding Door Window
Last answer on 4/23/2021 11:23:23 PM. by S L Gupta (Civil Engg). Forum started by Snehal Shah
2592
new constuction help required
Last answer on 5/3/2012 9:48:59 PM. by Ar. Manoj Ralen. Forum started by gaurav
1862
hi dear expert Need advice i have a plot 162 sq yard 27 feet breadth and 54 feet
Last answer on 9/17/2012 3:07:07 PM. by Anuj Kapoor. Forum started by Gaurav
2282
Kitchen Storage Ideas
Last answer on 8/25/2012 11:30:52 PM. Forum started by VijiRaghavan
4761
Dear Sir, I need your valued advice on my life and Job.My date of birth 22-06-19
Last answer on 1/25/2022 9:23:19 AM. by Monika. Forum started by Anil kumar s
2018
Last answer on 2/2/2022 11:26:31 PM. Forum started by manjunath
2591
Elevations Required
Last answer on 2/2/2022 10:53:23 PM. Forum started by gangula
3202
Cracks on the walls
Last answer on 1/14/2022 10:40:04 AM. by S L Gupta (Civil Engg). Forum started by devjani roy kashyap
2897
Wall painting
2083
CEMENT PANI - Plaster Works
1951
Triangle House roof
Last answer on 1/14/2022 4:58:49 AM. by S L Gupta (Civil Engg). Forum started by tayyab
3870
Last answer on 1/14/2022 4:09:54 AM. by S L Gupta (Civil Engg). Forum started by Sameer
2332
tiles or marble
Last answer on 12/4/2021 5:12:27 AM. by S L Gupta (Civil Engg). Forum started by aammiitt
3536
stone wall cladding
1515
help
1542
POP OR GYPSUM
10933
Lappam vs Wall Putty
1834
1961
1880
Final Handover
Last answer on 5/14/2014 2:15:33 PM. by S L Gupta (Civil Engg). Forum started by Ahmed
2117
2568
Thermal Insulation of Home
Last answer on 3/29/2010 7:23:40 AM. by abhijeet pawar. Forum started by akkulshrestha
Why
Proper
Pooja
Pooja Room Vastu
