Home -> Forums -> Construction -> Waste Water Drainage -> please help....slow draining in the bathroom
Wed Aug 31, 2011Total posts : 4
mvnisha
mvnisha
Topic: please help....slow draining in the bathroom
we just completed some renovation in our house and moved the washing machine to an existing bathroom.  the outlet was connected to the existing silt (fixed a grating with the big hole for machine outlet). the issue now is that the waste water back flushes every time the machine empties itself.  the water from the washing machine first fills the deep pipe with a gurgling sound and then starts filling up the bathroom and slowly drains. the drain, as we see, is a deep pipe, may be 2-3 feet deep.  we can also see two smaller pipes joining it half way through, perpendicularly.  one is the washbasin outlet joining the bathroom drain, and the other, we couldnt figure out as yet. the house is an apartment handed over long back and there is no way we can clarify it with the engineer.  is there anything we can do about this?  or is this a common issue because many people i talked to were narrating similar experiences in cases where the laundry outlet went into the bathroom drain.  is not the bathroom drains designed to take high volumes of water all at once?
Fri Sep 02, 2011Post  #1
Dear Mvnisha
As stated by you that the problem arises after renovation work. Some waste material filled in the pipe.You should contact any plumber who can solve your problem.
Fri Sep 02, 2011Post  #2
mvnisha
mvnisha
Post subject: thanks
thanks for the response Mr Gupta.  i don't think it started after renovation because this bathroom was more or less unaltered.  we just moved the washing machine in and did the necessary wiring for that. the outlet was connected to the existing drain point.
in this context, i think i should mention, the washing machine was earlier placed in the work area and connected to a similar drainage too. on removing the machine from its earlier place, we saw laundry dirt accumulated on the floor (which was not visible while the machine was there).  so i suspect a back flush there too.
 my doubt now is, are normal drainage (like the ones we usually have in the corner of the bathrooms in Indian houses) capable of draining such huge volumes of water like that from a washing machine in one go? as i mentioned, i had other people telling me they have the same issue when their machines empty to the bathroom drainage. thanks in advance
Fri Sep 09, 2011Post  #3
Solomon
Solomon
Post subject: Re: please help....slow draining in the bathroom
Hi, I am no expert but could think of this solution. Attach a smaller pipe through an adaptor to the water-outlet tube (available with your washing machine seller). Make sure the smaller pipe is lenghty. Check with your plumber who might give you a more practical solution since he can check at your premises. Regards
Mon Sep 12, 2011Post  #4
mvnisha
mvnisha
thanks solomon. that sounds practical, will surely try it out.  had been thinking of reducing the outflow with some obstructions over the outlet (like partially covering the mouth with a cloth or something). but if the solution u told works, it'd be better. hope the machine service centre has a smaller one available.
Waste Water Drainage-Construction Questions (25)
5097
Stop Rats from entering In house via Drain pipe
Last answer on 6/10/2011 11:47:24 PM. by P. Panchal. Forum started by P. Panchal
2321
1706
plan for bathroom size 4'*7'
Last answer on 8/18/2016 3:56:25 PM. Forum started by BALRAJ CHADDHA
1411
sir please help me i want to build 3bhk in ground and first floor my plot area i
Last answer on 11/16/2016 10:37:54 AM. by Beenu Phogat. Forum started by raghu
1824
the bathroom with the japanese tint could someone tell me the brand of the tub w
Last answer on 7/3/2020 11:55:14 PM. by Andy Reed. Forum started by Robert Beachum
2274
I live on 6th floor in a flat. my SW is cut off, kitchen, servant quater with ba
Last answer on 7/3/2020 9:17:06 PM. by Priti Arora. Forum started by payel
2383
I need 16*40 home sketch with vastu please help me
Last answer on 4/25/2013 10:39:22 AM. by Amit Hasija. Forum started by Sharath
2326
MY ENTRANCE IS IN WEST DIRECTION PLEASE HELP
Last answer on 11/26/2013 4:04:04 PM. by S L Gupta (Civil Engg). Forum started by SHAMBHAVI
5027
600 SFT ACC 2BHK Costing
Last answer on 7/4/2020 4:20:53 AM. by JAI PRAKASH. Forum started by bharadwaj
1966
Please please help for Plot size 12 by 60 feet West facing
Last answer on 9/2/2017 12:44:37 AM. by S L Gupta (Civil Engg). Forum started by Rahul
3803
Dear Sir Please help my House plan plot area 10 x 22.5 feet
Last answer on 8/4/2016 5:24:14 PM. by S L Gupta (Civil Engg). Forum started by Gopal Upadhyay
1082
South road face site please help
Last answer on 1/29/2019 12:48:59 AM. by S L Gupta (Civil Engg). Forum started by Rajeevalochana
1232
Last answer on 8/1/2018 11:29:01 PM. by S L Gupta (Civil Engg). Forum started by Pintu kumar
1333
hello,Can you please provide me the map plan for 20 by 50 mtr plot for making re
Last answer on 7/3/2020 11:14:59 PM. by S L Gupta (Civil Engg). Forum started by Ravi Yadav
7842
1570
Plot size 26*45 east facing please advice 2bhk with one attatch and one common b
Last answer on 1/15/2022 12:32:51 PM. by Beenu Phogat. Forum started by puneet dhir
1639
dear sir, we are required 17x38 plot area ground flor with parcking space, kitch
Last answer on 12/15/2016 2:04:30 PM. by S L Gupta (Civil Engg). Forum started by vijay
2001
1751
Design Fr the Bathroom
Last answer on 7/3/2020 9:23:23 PM. by S L Gupta (Civil Engg). Forum started by T RANJITH KUMAR
2030
whats remedy fr wall dampnass
Last answer on 2/25/2022 7:03:51 AM. by helloaarti21. Forum started by rakesh chopra
3291
2764
2388
Sewage and drainage lines
2504
2349
Traps - Types and Uses
Last answer on 7/3/2011 1:35:26 AM. by S L Gupta (Civil Engg). Forum started by SHAMS
Bathroom Pictures
Bathroom Lighting
Bathroom Accessories Part-4
Bathroom Decorating Ideas
Using
Small
Small Bathroom Ideas or Tips
