Home -> Forums -> Construction -> Start Construction -> What precautions should be taken while constructing leakproof Slab
Mon May 09, 2011Total posts : 3
tiwari_p_k
tiwari_p_k
Topic: What precautions should be taken while constructing leakproof Slab
I am going to start construction of Ground floor slab. As per diagram provided by my architect, I have Master Bedroom on first floor with attached toilet-bathroom in it. And exactly below that on ground floor I have kitchen. I heard by some of my friends that the after 7-10 years down the line, water leakage starts from slab area in toilet-bathroom. My concern is that this will cause water getting ripped in kitchen area after 7-10 years.
As the slab is yet to be constructed, I have 2-3 weeks of time, what precautions need to be taken in slab area corresponsing to toilet-bathroom on first floor, so that water will not get leaked into kitchen which is lying exactly below it on ground floor. Do I need to use any special precautions and any special material in contruction of slab for this?
Prashant
Tue May 10, 2011Post  #1
Dear Parshant
      Every slab should be leakproof not only for bathroom. Precaution should be taken that at the time of laying slab.
It is generally seen that mason and laborer walks on the newly laid cement concrete slab.
The contractor did not bother to finish the top surface of the slab by saying that I will do the shullary on the next day. But if after using the vibrator the slab surface should be finished first with wooden float after that the surface should be finished with iron float and no body is allowed to come after finishing at least for 4 hours than there is no question of leakage. The joints should be finished well.
Thu May 12, 2011Post  #2
Sreenivas Tummala
Sreenivas Tummala
Post subject: Water proofing your bathroom.
Dear Parshant,
Mr.S.L.Gupta might have helped you a bit by providing information about the precautions to be taken while laying your slab. Apart from the above precautions you can also avail the various water proofing coatings available in the market. For example Brushbond RFX from Fosroc, Boscolastic coating from Bostik. These coatings are to be applied to the slab surface before laying the tiles in your bathroom. You can approach the local applicators available in your city.
Sun May 22, 2011Post  #3
Moreshwar Kelkar
Moreshwar Kelkar
Post subject: Positioning of bathrooms.
Dear prashant,
I feel Vastu suggests a bed room in SW while the Kitchen in SE or NW corner; that apart wash platform (MORI) if  attached to kitchen on GF may be placed below Bathroom on FF. An integral sunken slab sloping towrds outer wall in the bathroom at the 1st floor may also help.
I too am facing leakage problem from FF after 8-10 years, making me lose faith in contractors. People suggest another slab as SF, which raises the question of  how many more? Wishing you the best of luck. Regards
3980
Roof leakage
2025
I had constructed 4" inch wall on the external wall on the first floor what prec
Last answer on 6/26/2019 10:39:50 PM. by S L Gupta (Civil Engg). Forum started by Badhavath Rajeshwar
1589
what precautions have to be taken for construction on South-West corner plot (46
Last answer on 9/15/2021 2:53:51 AM. by RadyGoldy. Forum started by prashant
4238
Digging of Borewell and precautions to be taken.
Last answer on 3/9/2015 11:43:42 AM. by Pavan. Forum started by PCR.Manohar
3157
I m starting my new business of construction , kindly help me with some details
Last answer on 7/24/2021 4:15:31 AM. by Rinder76. Forum started by Tarun
1971
What are the precautions required to be taken for south facing house.
Last answer on 12/11/2010 10:56:40 PM. by Amar Nath. Forum started by Amar Nath
1762
We are about the start the 1st floor slab of our bungalow. However, we are hesi
Last answer on 6/11/2011 4:08:47 PM. by S L Gupta (Civil Engg). Forum started by blossom
1506
Last answer on 10/31/2017 12:00:07 AM. by S L Gupta (Civil Engg). Forum started by div
2563
4057
2250
sir, what are the precautions need, to make a swimming pool on the roof.
Last answer on 10/6/2021 6:10:46 AM. by S L Gupta (Civil Engg). Forum started by Gagan Matharoo
2689
Last answer on 7/2/2021 3:17:17 PM. by B Thakar. Forum started by minhaj sk
11830
cost of rbc and rcc slab
2799
hai my house is constructed 7 years ago, now the roof slab is leaking year by y
Last answer on 7/3/2020 11:41:25 PM. by S L Gupta (Civil Engg). Forum started by vidya
191901
2050
I am planning to construct first floor on the existing house and like to know co
Last answer on 7/17/2013 11:49:00 AM. by S L Gupta (Civil Engg). Forum started by MANJUNATH
2576
Cost of Pillars and slab
Last answer on 6/13/2013 11:43:13 AM. by MANJUNATH. Forum started by MANJUNATH
1888
Dear sir(s), Is a south facing row house with service road in front, n
Last answer on 1/27/2012 10:48:45 PM. Forum started by B.S.BISHT
21875
3312
2236
2312
2061
Centering
What is Glass Window
A transparent opening in a wall is called window. Usually windows are covered by transparent or glazed material like g..
Termite Treatment for windows- Precautions and tips to remember
Termites are major wood destroying insects. We must take every precaution while doing any construction. Here are few t..
