Fri Jan 25, 2013 | Post #1 | GUNA
Join date: Feb 2012 | hi Ringwang, You are wright client can change the corrections at any time as per his requirement because he is the one going to live there, but it is contractor's responsibility to execute the work as per clients requirement, and there will be a cost involvement which has to be discussed and proceed further | |
Wed Jan 30, 2013 | Post #2 | S L Gupta (Civil Engg)
During construction, some time adition and alteration is required according to the better living condition.There are two things, one 12' height is sufficent for house. Second if you have increase the roof /slab height, than cost of construction is effected.
Its simple solution is that enquire the hire charges of ballies of 12' and 14' and pay the differance of hire charges to labour contractor. | |
Mon Feb 04, 2013 | Post #3 | atlantaroofingcont
Join date: Dec 2012 | Post subject: Atlanta Roofing Contractors
I have a rooftop Yakima box. Works great,
provides weather and security protection, I can park the van and leave
without worries.these things are brick shaped enough, adding something on the roof.....!!! | | | |
Brick Walls, Pillars and Structure-Construction Questions (39) | |
