Home -> Forums -> Construction -> Green Building -> roof farming
roof farming
Fri May 27, 2016Total posts : 1
raj
raj
Topic: roof farming
Good Morning to all experts . I am interesting in roof top farming with approx 900 sq feet of roof. please advice how to start.
Sat May 28, 2016Post  #1
Dear Raj
How to build roof garden
The first and most important step involved in making terrace garden is to identify the area of terrace where you plan to build a roof garden. Make sure that the roof on which you wish to have garden is strong enough to carry the weight of garden. The roof should not have any leakage of water in roof and it should have effective drainage system. Roof garden can be made on half of terrace leaving a patio to make a sitting place.
Water proofing of roof
Next step is water proofing the roof slab to prevent the seepage in the roof. A proper water proofing treatment should be done before building a roof garden. Chemical based water proofing treatment is more effective than covering based water proofing. After water proofing consult a landscaping expert for roof garden contract. Proper drainage pipes should also be laid over the roof slab. Make sure you have installed a water proof covering with the thermoplastic or rubberized sheeting. Filter sheet is also necessary to drain off the moisture form the roof slab.
Soil for roof garden
The top layer of the roof garden is soil it can be a mix of soil and manure. The top layer of roof garden should be light weight and layer can be 6 to 9 inches deep. After laying the soil it s time choose plants and grass for roof garden.
Plants for roof garden
Prefer fiber rooted plants instead of deep rooted plants for roof garden otherwise there is danger of the structural damage to the building. Plants with deep roots can be planted in big planters. Various designs of planter can enhance the beauty of roof garden. Before planting the flowers and plants it is necessary to keep in mind that hard plants should be planted in sunny side and plants require less sunlight should be planted in non-sunny side. Vegetables and shrubs can also be grow in roof garden, consult landscaping consultant to know which one is best for your roof garden. Heavy shrubs and vegetables with deep roots can harm building structure. Also prefer plants which have less requirement of water.
Roof garden is possible in a home, multi story building and commercial building terrace also. So, build a roof garden to make roof more inviting and beautiful.
Green Building-Construction Questions (38)
1490
i would like to construct a farm house with wood. if any body has good plans,pls
Last answer on 11/1/2011 2:28:17 PM. Forum started by nanajee
8405
Roof Beam crack
2546
New House Plan and Construction
Last answer on 7/4/2020 4:23:20 AM. by Shanthakumar. Forum started by Vaishnavi
2838
2361
Roof construction
12186
3966
Roof leakage
2028
4626
2313
2135
1819
1779
1633
2459
Farm House
Last answer on 11/3/2011 6:42:17 AM. Forum started by shadow
3254
Roof Concrete Strength
2337
laying of roof
1848
2236
sir, what are the precautions need, to make a swimming pool on the roof.
Last answer on 10/6/2021 6:10:46 AM. by S L Gupta (Civil Engg). Forum started by Gagan Matharoo
3254
Last answer on 1/24/2022 9:52:50 PM. by S L Gupta (Civil Engg). Forum started by Akash Sharma
3167
Architect to Build Green Modern Home in Bangalore
Last answer on 11/21/2021 1:07:48 PM. by fabions. Forum started by rahulsharma
2881
Help with a documentary about sustainability
Last answer on 10/5/2021 8:27:02 AM. by S L Gupta (Civil Engg). Forum started by Chibi Moku
3011
hpl panels for exterior
Last answer on 8/26/2021 8:40:25 AM. by HardissonHard. Forum started by kamal
2864
estimation
1786
Last answer on 7/4/2020 2:05:29 AM. Forum started by Alisson Chan
2131
Marriage Palace & School Auditorium
Last answer on 7/3/2020 11:27:36 PM. by S L Gupta (Civil Engg). Forum started by Marinedeejay
1755
House plan
Last answer on 7/3/2020 11:15:18 PM. by JAI PRAKASH. Forum started by udaykumar mugali
3469
Last answer on 7/3/2020 9:53:22 PM. by seema tyagi. Forum started by Modern Homes
1310
Is there any transparent sheets available for tress work on roof so as to cultivate on Terrance?
Last answer on 2/21/2017 12:33:33 PM. by S L Gupta (Civil Engg). Forum started by vinu
1669
Concrete Roof Insulation
Last answer on 6/25/2016 11:19:30 AM. by S L Gupta (Civil Engg). Forum started by Omar Chaudhry
1724
Solar energy integrated houses
Last answer on 7/6/2015 12:24:02 AM. by JAI PRAKASH. Forum started by Kumar
4182
Low cost housing option
Last answer on 8/11/2014 9:23:57 PM. by JAI PRAKASH. Forum started by Dinesh Sharma
2076
Low cost roofing solution over a slanting slab for internal cooling
Last answer on 12/1/2013 8:03:10 PM. by Girish. Forum started by Girish
1817
Cost of construction - Less expensive?
Last answer on 10/16/2013 12:53:12 PM. by S L Gupta (Civil Engg). Forum started by Prasad
2649
cost of construction of type G + 2
Last answer on 8/26/2012 4:08:55 PM. Forum started by santhosh
2701
Chemtreat India
Last answer on 9/8/2011 3:05:20 PM. Forum started by Chemtreat India
2230
interiors
Last answer on 7/15/2011 4:05:38 PM. Forum started by keerthi
Cooper
Aluminum
Aluminum Roof
Asphalt
Asphalt Shingles Roofing
Wood
Wood Roof Shingles
