Home -> Forums -> Construction -> Layout and House Plans -> school building
school building
Tue Feb 11, 2014Total posts : 2
Mohammed shoaib subhani
Topic: school building
Dear sir,iam planning to construct a school on my land at mehdipatnam.ithe total area of the land is 365sq yards.i am planning to construct 5 floors...with the stilt for parking.i am planning for medium costing...what would be the approximate costing? A plan will help me out a great deal.thank u.my plot dimension is 45 feet is the road facing..and 73 is the length.....thank u
Mon Feb 17, 2014Post  #1
Mon Feb 24, 2014Post  #2
Shanthakumar
Shanthakumar
Dear Shoaib,
Try to keep all floor plans same except parking - it helps to reduce complication and also bring down cost.
Use concrete blocks for wall - It bring down the total weight of the building and the construction process will be faster, also cost effective solution.
Shanthakumar,
Architect.
3647
if a school plot is cut from SW what is the remedy to rectify
Last answer on 7/3/2020 9:20:50 PM. by S L Gupta (Civil Engg). Forum started by anu
2605
iwant to see play schools false ceiling designs
Last answer on 7/3/2020 10:06:50 PM. by S L Gupta (Civil Engg). Forum started by manisha agrawal
2845
It is a school view
Last answer on 7/3/2020 9:30:36 PM. by JAI PRAKASH. Forum started by Arimoroolamilekan
2143
Marriage Palace & School Auditorium
Last answer on 7/3/2020 11:27:36 PM. by S L Gupta (Civil Engg). Forum started by Marinedeejay
2668
Hello,I am in the US (Washington State), and am thinking about becoming a certif
Last answer on 7/3/2020 9:59:36 PM. by sabina vanjani. Forum started by Mark Gregory
1830
Advise on laout plan
Last answer on 2/18/2014 12:18:28 PM. by S L Gupta (Civil Engg). Forum started by Ajay Kostha
1587
it is said that no growth of structures is permitted in est and north of our bu
Last answer on 4/29/2011 10:37:25 PM. Forum started by D.Ramachandran
1775
ROOFING
Last answer on 4/15/2015 9:28:05 AM. by mohit. Forum started by mohit
2125
Want to build 30*35 residential building suggest me some plans
Last answer on 1/5/2022 12:37:08 AM. by sweety. Forum started by ihsan
2006
3501
2845
Construction of new office bilding
Last answer on 2/22/2022 6:39:38 AM. by Anupam Anurag. Forum started by sushil singh
3304
GFRC Construction
6147
2023
2330
3425
1869
i really like this building and will like to know if i can get the plan for the
Last answer on 3/4/2012 7:48:08 PM. by polamset. Forum started by ralph
2691
2924
2188
2184
2791
4520
1890
2284
2265
2766
3464
2356
1967
2242
3595
2324
2090
2792
1548
2114
Orientation
Orientation of Building
Cupola Proportions
Tips for cupola proportions
Fire
How to Design a Garage
Comparison
