Home -> Forums -> Construction -> Cement Concrete Flooring -> What should be the floor concrete thickness after filling the foundation using quarry slurry?
Wed Dec 07, 2016Total posts : 1
Topic: What should be the floor concrete thickness after filling the foundation using quarry slurry?
I have filled the rubble foundation using quarry slurry which is of low cost but not strong/dense as earth filling. So, what is the safest thickness of floor concreting above it? Should I use steel bars as reinforcement in floor concreting?
Wed Dec 07, 2016Post  #1
Dear Vinu,
          Lay 4'' thick cement concrete 1;8;16 on the area which is filled by query dust. Then lay another layer of 3'' cement concrete 1;4;8 in whole the room' area under the floor.
Cement Concrete Flooring-Construction Questions (27)
2957
Need suggestions
2259
Using MSamd slurry for filling house foundation.
Last answer on 10/26/2015 12:05:05 PM. by S L Gupta (Civil Engg). Forum started by Vinod
3866
2587
mortar thickness in brick joints in foundation
Last answer on 8/23/2011 8:47:15 PM. by S L Gupta (Civil Engg). Forum started by ahsan
2063
concrete filling
Last answer on 4/18/2014 7:54:24 PM. by shaik khaja nayab rasool. Forum started by shaik khaja nayab rasool
2121
Floor thickness
Related to Sunken Slab
2535
RCC column (pillar)
3317
My plot is 5 feet below the road level. Will fill it up with sand after the foun
Last answer on 4/25/2018 1:12:52 AM. by S L Gupta (Civil Engg). Forum started by RAJAT BANGA
9195
3038
use of tmt bar
1897
What are various accessories recommended for wooden doors?
Last answer on 2/21/2014 11:53:38 AM. by S L Gupta (Civil Engg). Forum started by satish
2061
treatment for white ants
Last answer on 9/20/2014 12:17:36 PM. by S L Gupta (Civil Engg). Forum started by richlyn
2036
2707
2301
2032
1778
2327
Roof flooring
3589
Per Sq:ft rate for flooring
1398
Colored concrete floor
Last answer on 10/22/2016 11:14:47 AM. by S L Gupta (Civil Engg). Forum started by Pooja
1521
concrete floors
1989
1641
floor construction
2121
Floor thickness
2465
Material and cost of Tezzarro flooring
Last answer on 7/20/2012 11:33:53 AM. by S L Gupta (Civil Engg). Forum started by Raj
Designing
Designing a Foundation
Earth Filling
Hard
Using
Skylight
Concrete Decor
