Home -> Forums -> Construction -> Steel -> What is the standard size and spacing for TMT bars for the flat RCC roof of house where max. room size is 13x13feet?
Wed Jan 25, 2017Total posts : 1
Topic: What is the standard size and spacing for TMT bars for the flat RCC roof of house where max. room size is 13x13feet?
What is the standard size and spacing for TMT bars for the flat RCC roof of house where max. room size is 13x13feet and total area is 1300 sqft.
Fri Jan 27, 2017Post  #1
Dear Vinu,
          Use 12 mm dia tor with the spacing 6'' c/c for 13' span if span is 10' than use 10 mm dia tor steel bars.
24765
3753
4069
steel requirement
2529
duct size for and kitchen
Last answer on 7/3/2020 11:52:01 PM. by seema tyagi. Forum started by Yogender Singh
1780
3425
2728
VENTILATION FOR BED ROOM
Last answer on 8/22/2013 5:28:15 PM. by GUNA. Forum started by bharati.pradeep7
3837
Roof Beam
4647
3224
Size of TMT bar for RCC main slab and beam
Last answer on 1/27/2017 3:25:08 PM. by Rahul. Forum started by Rahul
2849
1st floor partition wall through the center of 14ft x 13 ft room rcc roof
Last answer on 11/1/2015 6:50:49 PM. by JAI PRAKASH. Forum started by vinu
19153
Last answer on 7/3/2020 10:47:35 PM. by S L Gupta (Civil Engg). Forum started by Techman
5170
3795
3039
use of tmt bar
2613
1622
2684
steel requirment
15582
1992
Residential complex
4367
RCC Columns
3238
7479
Bar Bending Schedule Software
2521
steel
29941
2613
9362
2260
Current iron rod price
1885
Steel Erectors
2382
3266
13772
overlap length to steel
2160
2539
Right size cupola
TMT
Type
