steel requirement
Tue Aug 20, 2013Total posts : 4
Raghavendra
Raghavendra
Topic: steel requirement
I am constructing a house of area 1200 sq/feet, single floor, no beams, no spans, rcc slab (4 to 5 inch) on walls, how much tmt bars (weight) required and  what sized tmt bar required?? How many cement bags required for that rcc ??
Wed Aug 21, 2013Post  #1
Dear Raghavendra
               The actual quantity of steel bars can be calculated with the help of plan of the building and structural design. How ever a rough estimate is cement required for slab in 1;2;4 ratio is 85 bag where as in 1;1.5;3 ratio 100 bags for 4.5 '' thick RCC slab. The quantity of steel bars is 1200 to 1400 kg. Use 10 mm dia steel bars for slab.
Mon Dec 21, 2015Post  #2
Pooja
Pooja
Post subject: concrete grade
I have house plan for 22.5* 40.  Max room size is 11*11. All room corners has columns.  My mistri has 30 years of onsite experience in residential construction.  I told him to use m15 in column footing and m20 in columns above plinth level. He said for above mentioned grades we need vibrator and concrete mixer which is not economical option for smaller plots having maximum span less than 16 feet. He told me to use 1:2.5:4 through out the columns upto 2 storey building as we needed to mix concrete by hand and if bajri is more then concrete will not get smooth.
    1:2.5:4, or 1:3:3 or 1:3:4 is prevailing commonly in our area when I asked some other mistris.
He will be using mixer and vibrator for rcc slab only
What to do sir?
Mon Dec 21, 2015Post  #3
te
        For hand mix concrete labor do some extra work to mix concrete. use proper ratio 1;1.5; 3 and vibrate with bamboo os Ms steel bars.Mason try to mix more sand and more water so that work is done without any hassle. If necssary mix some coarse sand extra.
Thu Dec 24, 2015Post  #4
You need around 1.8-2.0 tonne of tmt bars. For beams 16 mm. For Lantel 10 mm and 12 mm. You need around 70-75 bags of cement for the Lantel.
4330
15582
2898
RCC Roof
2216
RCC + Brick work estimate for 2400 sq ft construction
Last answer on 5/6/2014 5:04:11 PM. Forum started by nilesh
2131
what are requirements of RCC cantilever length?
Last answer on 12/24/2014 11:46:06 AM. by S L Gupta (Civil Engg). Forum started by syed basha
2125
construct of new house
Last answer on 12/24/2015 4:15:00 AM. by JAI PRAKASH. Forum started by renu
2865
2087
requirement ofconstruction materiales details per sft
Last answer on 1/5/2022 1:01:21 AM. by S L Gupta (Civil Engg). Forum started by K.S.RAJKUMAR
3205
Please give me a good looking low budget 10x12 bed room furnishing with all requ
Last answer on 6/11/2012 5:22:27 PM. by Gunjan Utraja. Forum started by Mandeep Sharma
2668
send me the detail of jaccuzi bathtub requirements of room size, expnditure, mai
Last answer on 1/28/2022 9:46:56 AM. by Priti Arora. Forum started by prabhuraj
1670
Last answer on 5/3/2016 12:13:14 AM. by JAI PRAKASH. Forum started by sayeedmohsin
4939
COLUMN AND STEEL DESIGN
4939
1557
Steel Buildings in Southern Florida
Last answer on 5/29/2018 11:30:11 PM. Forum started by Jason Gullett
3206
steel
3721
4949
Type
HSD
Precautions
What are requirements of drainage and sanitation for dwelling area covered with individual?
Requirements of drainage and sanitation for dwelling area covered with individual- One bathroom provided with a tap.....
Steel
Steel Roofing
TMT
