Home -> Forums -> Construction -> Green Building -> Is there any transparent sheets available for tress work on roof so as to cultivate on Terrance?
Mon Feb 20, 2017Total posts : 1
Topic: Is there any transparent sheets available for tress work on roof so as to cultivate on Terrance?
I want to know whether any transparent sheets available for tress work on Terrace like poly-house so as to grow plants on Terence.
Tue Feb 21, 2017Post  #1
Dear Vinu,
        There are so many quality of transparent sheet, You should contact at hardware store.
Green Building-Construction Questions (38)
1366
what would be total expense to install rubber sheet on roof of 780 sqft
Last answer on 9/24/2016 12:49:20 PM. by S L Gupta (Civil Engg). Forum started by DHIRENDRA
8401
Roof Beam crack
2806
1813
1776
6292
terrace flooring
Last answer on 7/3/2020 10:25:00 PM. by JAI PRAKASH. Forum started by Radhika
1417
I am planning to build a cost effective house. I like to explore use of metal sh
Last answer on 12/8/2016 12:32:51 PM. by S L Gupta (Civil Engg). Forum started by sasi raman
2394
2746
Iron Sheet Roofing
Last answer on 6/2/2012 7:25:01 PM. by skjain20002000. Forum started by Mr Marea Itaia
2973
3587
18413
2115
Sir I am having a rcc sheet roof of 60*12 feet now the sheets was gone I want to
Last answer on 11/5/2014 12:31:16 AM. by JAI PRAKASH. Forum started by srikanth
2125
Roof insulation
Last answer on 9/20/2014 12:13:54 PM. by S L Gupta (Civil Engg). Forum started by sb
1778
Can someone tell me roof insulation details. or if someone can guide me for the
Last answer on 8/8/2017 2:02:31 AM. by S L Gupta (Civil Engg). Forum started by Aqua
4622
2312
1844
Grill enclosure for washing machine on terrace
Last answer on 6/9/2014 11:35:43 AM. by S L Gupta (Civil Engg). Forum started by Sheela
1819
roof farming
Last answer on 2/25/2022 4:26:25 AM. by S L Gupta (Civil Engg). Forum started by raj
3251
Last answer on 1/24/2022 9:52:50 PM. by S L Gupta (Civil Engg). Forum started by Akash Sharma
3165
Architect to Build Green Modern Home in Bangalore
Last answer on 11/21/2021 1:07:48 PM. by fabions. Forum started by rahulsharma
2878
Help with a documentary about sustainability
Last answer on 10/5/2021 8:27:02 AM. by S L Gupta (Civil Engg). Forum started by Chibi Moku
3006
hpl panels for exterior
Last answer on 8/26/2021 8:40:25 AM. by HardissonHard. Forum started by kamal
2862
estimation
1784
Last answer on 7/4/2020 2:05:29 AM. Forum started by Alisson Chan
2129
Marriage Palace & School Auditorium
Last answer on 7/3/2020 11:27:36 PM. by S L Gupta (Civil Engg). Forum started by Marinedeejay
1753
House plan
Last answer on 7/3/2020 11:15:18 PM. by JAI PRAKASH. Forum started by udaykumar mugali
3467
Last answer on 7/3/2020 9:53:22 PM. by seema tyagi. Forum started by Modern Homes
1668
Concrete Roof Insulation
Last answer on 6/25/2016 11:19:30 AM. by S L Gupta (Civil Engg). Forum started by Omar Chaudhry
1721
Solar energy integrated houses
Last answer on 7/6/2015 12:24:02 AM. by JAI PRAKASH. Forum started by Kumar
4181
Low cost housing option
Last answer on 8/11/2014 9:23:57 PM. by JAI PRAKASH. Forum started by Dinesh Sharma
2074
Low cost roofing solution over a slanting slab for internal cooling
Last answer on 12/1/2013 8:03:10 PM. by Girish. Forum started by Girish
1816
Cost of construction - Less expensive?
Last answer on 10/16/2013 12:53:12 PM. by S L Gupta (Civil Engg). Forum started by Prasad
2648
cost of construction of type G + 2
Last answer on 8/26/2012 4:08:55 PM. Forum started by santhosh
2697
Chemtreat India
Last answer on 9/8/2011 3:05:20 PM. Forum started by Chemtreat India
2224
interiors
Last answer on 7/15/2011 4:05:38 PM. Forum started by keerthi
Iron
Iron Sheet Roofing
ACC
ACC Sheet Roofing
Cooper
