Home -> Forums -> Construction -> Outdoor -> time gap in construction phases
Tue Dec 06, 2011Total posts : 2
Manish
Manish
Topic: time gap in construction phases
i started constructing the ground floor of my duplex on 24th oct. 2011. My construction pattern is 'confined Mansonary' (RCC) . The foundation work was completed on 20th nov. The brick work was finished on 30th Nov.
Now i want to know that how much 'rest period' should be given before lintel. my contractor wants to construct lintel on 15th Dec. and he wants to start the brick work for the second story on 1st Jan 2012. & the lintel of second story by 30th Jan 2012. Will this 'time gap; be correct /sufficient or not.?
Thu Dec 08, 2011Post  #1
Dear manish
             After laying the RCC slab/ roof ,the time gap must be 10 days. for other work no time gap is required.
Thu Dec 08, 2011Post  #2
Manish
Manish
Thanks for clarifying my doubt.
2232
Last answer on 3/5/2016 9:22:48 PM. by JAI PRAKASH. Forum started by saideep
1708
I plan my construction for 30*83 feet size north phasing plot, give me some vast
Last answer on 6/21/2016 12:58:07 AM. by Beenu Phogat. Forum started by PARAMJIT KUMAR CHUMBER
2126
1637
Hi ,I want to know after construction how much time I will start wall pop for sm
Last answer on 10/27/2015 6:41:05 PM. by JAI PRAKASH. Forum started by Anu
527
How can I make a small garden pond in my backyard? When is the best time to carr
Last answer on 1/26/2022 7:40:55 PM. by Anniesa. Forum started by Sally
2339
my question is can we built one temple beside my home just one feet gap
Last answer on 9/8/2010 1:01:25 PM. Forum started by Rajashekar
1796
Planning to construct a building for an orphanage
Last answer on 5/3/2016 11:30:34 PM. by JAI PRAKASH. Forum started by Gopinath
1942
Construction cost
Last answer on 4/8/2014 4:11:47 PM. by awdhesh. Forum started by awdhesh
5223
2944
2225
Iam rajashekar, my question is .Can we built one temple beside the house. (just
Last answer on 9/8/2010 12:56:07 PM. by sabina vanjani. Forum started by Rajashekar
1734
485
How can I relax a little and have a good time?
Last answer on 2/22/2022 6:41:35 AM. Forum started by John Staples
2083
Where can I find work in times of crisis?
Last answer on 1/5/2022 11:59:10 AM. by TommyUno. Forum started by segment
1552
do you play games in your free time?
Last answer on 1/23/2022 2:51:30 PM. by Kyditiaur. Forum started by Salammm
946
How to pump wow to 60-70 leveling in a short time?
Last answer on 2/20/2022 8:22:09 PM. Forum started by aglar
574
Picnic as a way to spend your leisure time with friends
Last answer on 11/4/2021 4:23:03 AM. by Rinder76. Forum started by Rinder76
2338
PAINTING
Last answer on 6/14/2011 1:16:15 PM. by S L Gupta (Civil Engg). Forum started by sabakhan
3156
Basement waterproofing
2866
Steel calculation
1759
6693
6356
11378
10721
Life span of RBC lintel roof
2090
Foundation
3570
R.C.C. column in Sqft
2279
Plumbing works
1588
New 4 storey building design
1905
earth filling under floor
1774
want a parking
2404
2268
2565
foundation plan.
Last answer on 12/15/2011 2:31:13 PM. by Ishmael Mphande. Forum started by Patrick Salasini
2501
Re-Construction
3014
cracks in walls
Cupola Proportions
Tips for cupola proportions
