Fri May 25, 2012 | Total posts : 3 |
| Topic: How to Build Septic Tank for house
Dear sir, Please guide me how to make septic tank. some people make partition of flag stone in septic tank. but contracter don't want to make partition. he says no partition required. where outlet pipe start, there he puts an elbow and a peforated pipe hangs down -ward 2 feet (holes about 10 to 15 mm all around hanging pipe) pls guide me what is better way. or any third or best way to make septic tank.Thanx in advance |
Sat May 26, 2012 | Post #1 | S L Gupta (Civil Engg)
Septic tanks or soak pits are useful for disposal of waste in the areas or houses where public sewerage system is not applicable.Please see the link below
Sun May 27, 2012 | Post #2 | P. Panchal
DEar sir, thanx for ur quick response, But my question is that if we dont provide stone partition in septic tank, than what problem may arise. is there any other altenative to make septic tank
Thu Sep 20, 2012 | Post #3 | PR Jawahar
Join date: Sep 2011 | Post subject: How septic tank works
Hi Panchal,
Hope the attachment provides you some information on how septic tank works and how the partition wall helps..
Foundation-Construction Questions (39) | |
Articles that might interest you! | | Septic Tank, It’s Principle and Guidelines Septic tanks or soak pits are useful for disposal of waste in the areas or houses where public sewerage system is not .. | | Water Storage Solution Storage of water in proper way is essential for drinking, cleaning, bathing, cooking purposes in our day-to-day life. .. | | Orientation of Building To get maximum ventilation and natural light in your house, make sure the building is properly oriented. Orientation o.. | | Gharexpert can save you money during construction Do you know almost all individual home construction projects in India take more money to complete than what people ori.. | | Vastu for Water Tank It is important to place water bodies in Vastu friendly manner to preserve resources and energies. Under ground water .. | | Preventive Measures for Leakage from Water Tank The following measures should be taken during construction of water tank to prevent the leakage. These preventive meas | | Which Are Various Reasons of Cracks in Buildings? Cracks can happen due to foundation movements and settlements of building, thermal movements, chemical reactions, elas.. | | Building New Home V/S Buying Builder Flat Buying a builder’s flat may be costlier for you rather than building a new home. But if you plan to make your own, you.. | | Environmentally Friendly Houses An environmentally friendly house is designed and built to be in tune with its occupants, nature, environment and ecos.. | | Environment Friendly Houses An environment friendly house is designed and built to be in tune with its occupants, nature, environment and ecosys | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
