Home -> Forums -> Construction -> Brick work -> How to protect concrete window and door frames from sticking cement particles during construction?
Mon Dec 05, 2016Total posts : 1
Topic: How to protect concrete window and door frames from sticking cement particles during construction?
Tue Dec 06, 2016Post  #1
Dear Vinu,
         Protect the frame with thick paper or polythene. The other method is to clean the splaces of cement daily.
5227
3490
5019
5224
2732
2739
i need.s windows aluminium with gllas & fire doors pvc construction in india l
Last answer on 2/24/2022 1:02:52 AM. Forum started by muhammad mansoor
2525
2986
how many type(colour)s sal wood is there . which is good for making frames for d
Last answer on 6/25/2014 1:38:01 PM. by S L Gupta (Civil Engg). Forum started by sathish
2222
DOOR & WINDOW FRAMES
Last answer on 6/7/2015 1:21:11 AM. by JAI PRAKASH. Forum started by Snehal Shah
5316
Alternative materials for Modular Kitchen
Last answer on 7/27/2013 7:55:03 PM. by Pooja. Forum started by GULSHAN RAI GULATI
2607
Window position on wall
3088
What type primer and paint should be used for concrete window and door frames?
Last answer on 6/5/2017 12:48:40 PM. by S L Gupta (Civil Engg). Forum started by vinu
1767
1460
1735
3658
2847
Can u pls send me price for upvc door and door frame.Thomas
Last answer on 7/4/2020 3:07:03 AM. Forum started by Thomas Rodrigues
2994
2523
3670
wals
3264
compound wall
21879
3280
Bedroom Wardrobes information
2246
2207
1495
1732
2225
2523
1502
1910
Brick or ACC block
1654
2153
1702
4688
Brick wall on RCC slab
3929
2618
Ready
Ready Mix Concrete
Door
Door and Window Frames
Protect
Protect Your Family from Dust
Protect
Protect your Home from Bugs
