Home -> Forums -> Construction -> Cement Plastering -> How to remove polythene sheets from old concrete ceiling
Sat Oct 24, 2015Total posts : 7
sira
sira
Topic: How to remove polythene sheets from old concrete ceiling
The ceiling of our house was not plastered since 15 years.
 But the polythene sheet was not removed then. Now the polythene is not getting removed easily or it is breaking like Papad. Brushing is not helping.
So please suggest a way-out to remove polythene sheets from old concrete ceiling.
Sun Oct 25, 2015Post  #1
Vinod
Vinod
What about using wirebrush hand grinder for smooth grinding the problem areas?
Sun Oct 25, 2015Post  #2
Er.S.K.Jain
Er.S.K.Jain
If concrete and polythene left from more than one month it is not easy to remove it.
You left for 15 years so now the polythene removal completely is not possible.
you remove by wire brush as much as possible and after that chipping on concrete surface than apply neat cement after that spray some corse sand over it than plastered.
Sun Oct 25, 2015Post  #3
Why to remove it? You can go for finishing now like POP not plaster if you want.
Mon Oct 26, 2015Post  #4
      You should  first  wet the ceiling and remove the polythene sheet by wire burnishing.
After that do all process as suggested by Sh SK Jain.
Sat Dec 19, 2015Post  #5
P.K.SAMAL
P.K.SAMAL
Post subject: remove s polytheneheets from old concrete ceiling
At the time of removed centering polythenesheets was not removed.After six months we are facing lot of problems to remove it.Kindly suggest me procedure
of removeing  polytheneheets .
            Is there any chemical to solve this problems.
Thu Dec 24, 2015Post  #6
Use wire brush as suggested.
Wed Nov 21, 2018Post  #7
Swapnali
Swapnali
The ceiling of our house was made before three months. But the polythene sheet wasn't removed then. Now the polythene isnot getting removed easily. Brushing isn't helping. So please suggest a way-out to remove polythene sheets from the concrete ceiling ..
3435
sunmica
Last answer on 12/6/2012 10:52:25 PM. by shailesh kumar singh. Forum started by tanaji
2924
2724
1699
My House is 10 years old and my Existing Concrete roof in Hall area started to p
Last answer on 4/5/2018 12:46:08 AM. by S L Gupta (Civil Engg). Forum started by soundar
8419
Roof Beam crack
1794
Removing ceiling from old constructed house
Last answer on 4/30/2010 11:57:04 PM. by . Forum started by VIMAL MATHIMARAN
1708
Driveway Reconcreting
Last answer on 1/23/2016 8:41:13 PM. by JAI PRAKASH. Forum started by gpeter
1066
4763
Last answer on 8/27/2012 4:35:27 PM. by Amit Hasija. Forum started by prakash
2567
2828
1736
weather proof repair reg
2384
Ceiling designs
Last answer on 9/2/2010 8:40:06 PM. by . Forum started by shirley
2150
seal coat on roof
Last answer on 9/19/2010 11:16:18 PM. Forum started by viswanath
1966
while building an extension building next to old one the ceilings were kept apar
Last answer on 8/20/2011 2:20:45 AM. Forum started by D.Ramachandran
2080
Last answer on 10/23/2010 3:33:17 PM. Forum started by sandeep Dholakia
1980
north to south face 4 bedroom plans 1800 sheet 48 chorai 35 lainth map images
Last answer on 2/25/2015 9:23:56 AM. by seema tyagi. Forum started by neelam
2309
New Home
1380
what would be total expense to install rubber sheet on roof of 780 sqft
Last answer on 9/24/2016 12:49:20 PM. by S L Gupta (Civil Engg). Forum started by DHIRENDRA
2929
Plaster
2780
Plaster work
3046
Plastering
1924
2003
PPC and OPC cement
1870
suggest for exterior
7004
9157
1876
OPC and PPC cement
2156
2011
coarse aggregate
1826
Nice
2436
Gypsum Plaster Vs S/C Plaster
2173
Outer Plaster
2996
2734
putty work on walls
2236
2825
2032
How to clean plaster ceiling?
How to Paint Old Furniture
Surface
Dining
Dining Room Ceiling
Kids
Kids room ceiling designs
Concrete Decor
Ceiling
Bed Sheets For Your Bedroom
Bed sheets are the quickest way to refresh tired furnishing of your bedroom. Comfortable and shining bed sheets with ..
