traditional house construction
Thu Feb 20, 2014
vikram
Topic: traditional house construction
Dear Sir, I
want to build a traditional house (2000 sq ft area) with centre potion le
ft open for AANGAN, similar to houses found in kerala or rural india. with no RCC
columns or beams
, only
f
i
rst floor will have RCC foof and next will be roof with Clay tiles..the construction site is in Mayapur (dist- Nadia, west bengal) ..sug
gest the estimate..also s
uggest best ma
terial viz bricks or stone for that environment.
Fri Feb 21, 2014
Dear Vikaram
For estimate and drawings contact support@gharexpert.com.
Mon Feb 24, 2014
Shanthakumar
Hi Vikaram,
All 2000 sqft area building might not cost the same. Cost estimation is nothing but the cost of material required for construction and lobour cost. It involves the process of finalizing the design / material specification before quantify each material. Otherwise the estimation would show wrong figure. Sometime you might be overcharged as well. I suggest you to finalise the design before estimation. You can revise the design based on your budget.
Shanthakumar.
Architect.
2487
new house
Last answer on 8/1/2018 11:41:51 PM. by
kalyan
2377
open kitchen is better or the traditional one
Last answer on 1/23/2022 3:37:50 AM. by
gayatri
1598
Last answer on 1/5/2022 8:30:54 PM. by
Pranav
1993
Can some one advice on the issues involved in designing a double stored roof wit
Last answer on 1/29/2010 6:25:52 PM. by
Anil Kumar Sood
1934
i want to decorate my drawing roon walls in a traditional indian way so suggest
Last answer on 7/3/2020 11:09:19 PM. by
aashee
4074
Last answer on 7/4/2020 2:32:53 AM. by
satish
3879
Last answer on 9/22/2021 6:50:36 AM. by
Last answer on 12/14/2020 9:46:53 PM. by
Mubarak Khan
1595
Checklists for flooring
Last answer on 4/4/2015 7:09:35 PM. by
MUTHU
1809
Last answer on 1/27/2016 12:04:33 PM. by
A Ghosh
2019
Last answer on 7/3/2020 10:54:45 PM. by
zakia sultana
1783
Last answer on 3/17/2021 12:53:46 PM. by
MD KAMIL RASHID
2572
house construction plans for 20x30 site
Last answer on 7/4/2020 2:28:10 AM. by
Amrit Bhagat
ramu
2616
COLUMN nd LOAD BEARING
Shivaraj
Shivaraj
2299
Last answer on 2/22/2022 2:58:13 AM. by
Vishal
2991
1681
Dear sir my house construction is going very well but my house front side EB pow
Last answer on 10/12/2015 10:30:39 AM. by
balamurugan
1509
Last answer on 9/5/2016 11:51:29 AM. by
Traditional Style
Traditional style interior offers classy, relaxing and calm look to your home. Soft color schemes, paintings, wall han..
