Home -> Forums -> Construction -> Raw Material -> wirecut clay bricks vs concrete bricks, which one is better for load bearing walls?
Sat Jul 23, 2016Total posts : 1
Topic: wirecut clay bricks vs concrete bricks, which one is better for load bearing walls?
I'm from south India where everyone prefer traditional clay bricks or wire-cut clay bricks, which are manufactured using machines so more unique in dimensions, over concrete bricks for house construction even though clay bricks are costlier than concrete bricks and it adds additional construction cost in terms of more cement, sand and manpower requirement. People choose the cement bricks only if the clay bricks are not with in their budget.
So, my question is whether the clay bricks are superior to concrete bricks in terms of strength, durability and quality for load bearing walls?
Which one is better for withstanding the shearing forces like earthquake?
Is it true than concrete bricks loose its bonding strength and more prone to deterioration in long run compared to clay bricks which keep its properties unchanged for decades?
Here, people believe that concrete brick houses are hotter than clay brick houses. Is it true even if we protect the walls from direct sun light ie. planting trees etc.?
So, I would like to hear from experts that whether there are any strong reasons to choose clay bricks over concrete bricks for house construction and to justify the increased construction costs? Please help.
Wed Jul 27, 2016Post  #1
Dear Vinu
        In terms of strength, durability and load bearing cement concrete brick is better than clay brick.
For earth quack both have no much difference..
Bonding strength of concrete brick is less as compare to clay brick.
1800
2867
Bricks
3996
2154
1345
10055
4065
6459
9210
2875
FLYASH OR CLAY BRICK
3086
3124
concrete brick or clay brick
7518
Brick Advice Urgent
3462
2708
Exterior wall Construction Best method
Last answer on 9/28/2011 7:09:37 PM. by Chatar Singh. Forum started by sunny420
7270
2531
15368
2nd floor construction
3080
RCC roof
1974
Marriage hall construction
2541
Function Hall
4209
11118
2196
2042
Estimate
11129
3077
Steel
3041
use of tmt bar
1647
work turned out by labour
2460
estimate
1766
3609
1945
Cost of Steel construction
1617
2140
READY MIX PLASTER
1867
2228
zero slump concrete
Various Types of Bricks
Brick Arches
Specification of Brick
Bricks Quality
Brick Pillar
Concrete Mix Ratio
