Wed Jan 16, 2013Total posts : 2
selva
selva
Topic: Lindle beam at 7 feet or roof level beam at 10 feet
What is correct way to do beam on wall and roof?
1. Lindle beam at 7 feet level with roof on brick at 10 feet
or
2. Roof level beam at 10 feet with roof on beam
or
3. Lindle beam at 7 feet level and roof level beam at 10 feet with
roof sitting on roof level beam.
Note this construction will be ground + 2 floor (total 3 levels)
And this structure will be on pillar at all jointes.
Thu Jan 17, 2013Post  #1
Dear Selva
         The  lintle is laid on the door level and it is act as beam. when span is less then we call it lintel. As per your quarry this all depends upon the situation at the site and design to be adopted according to loading.
If you have door or opening than you have to lay the lintel beam at 7feet height and you can lay the roof slab on the brick work, there is no harm on this kind of arragements.
If you have opening and want to take opening up to 10 feet height than lay the beam at roof level.
If you have opening and want to close it 7feet height and have any type of ventilator or any other opening above 7feet, than lay the lintel at 7feet height and you have to lay the beam with roof to cover ventilator.
These all arrangements are according to site requirement.
Secondly now in design for earth quack safety, one have to lay lintel/beam at roof level and use cement concrete ratio 1;1.5;3 instead of 1;2;4.
Fri Jan 18, 2013Post  #2
gnyoganarasimhan
gnyoganarasimhan
Post subject: Lintel beam at 7feet or roof level bean at10 feet
Dear Sri Selva
Your question was what is correct way to do beam on wall and roof.
The answer according to me is your third option.That is lintel at 7feet level and beam at roof level.
When a small beam of short span is laid over door/window/opening it is called LINTEL.
Some provide a continuous lintel at 7feet level.While others provide cut lintels over door/window openings only.
Everything depends on various factors including plan,place budget etc and the reply given is generic
If you need specific answer for a particular plan this can be discussed in detail with
GharepertGharepert
Roof Beam
3273
Roof Concrete Strength
3657
1979
2720
4665
Regarding Beam
3575
2054
3152
Steel in Lintel
Last answer on 7/4/2020 3:06:52 AM. by JAI PRAKASH. Forum started by krishna pratap
4040
1871
I have 10 feet width and 84 feet depth plot, how I construction students lodge
Last answer on 10/4/2015 12:49:06 AM. by JAI PRAKASH. Forum started by chandan
2268
Dear Sir
Last answer on 3/9/2013 11:21:57 AM. by S L Gupta (Civil Engg). Forum started by Sreenivas Kumar
2091
Roof TMT needs
Last answer on 12/29/2015 12:27:55 PM. by S L Gupta (Civil Engg). Forum started by Rohit Sharma
2739
Regarding roof beam
5862
2630
Roofing elevation
Last answer on 12/24/2014 4:28:01 PM. by S L Gupta (Civil Engg). Forum started by Sai Pavana
3739
Hi Now I am in the construction, my kitchen is 10 feet x 10 feet, your expert is
Last answer on 8/1/2018 11:35:24 PM. by S L Gupta (Civil Engg). Forum started by kannaa
3669
wals
23
27
Centering
What is acre
Designing
Designing a Foundation
Through
Dining
Dining Room Ceiling
